My contribution to spanish gimp documentation
My contribution to spanish gimp documentation Guiu Rocafort 11 Sep 15:57
  My contribution to spanish gimp documentation Ulf-D. Ehlert 12 Sep 11:03
   My contribution to spanish gimp documentation Guiu Rocafort 13 Sep 12:45
    My contribution to spanish gimp documentation Ulf-D. Ehlert 13 Sep 20:27
    My contribution to spanish gimp documentation Julien Hardelin 14 Sep 06:04
Guiu Rocafort
2012-09-11 15:57:24 UTC (over 12 years ago)
Hey list !
I've been translating the spanish documentation. I attach the patch with the changes I made.
I also have a question, i've been trying to find what .po file contains the gimp-introduction-whats-new.html text, but I'm not able to find it. I would have translated and revised more of the manual, but unfortunately I'm stuck with this problem.
Thank you Guiu Rocafort
Ulf-D. Ehlert
2012-09-12 11:03:08 UTC (over 12 years ago)
On Tue, Sep 11, 2012 at 05:57:24PM +0200, Guiu Rocafort wrote:
Hey list !
Thanks. I have committed your patch and also checked if the resulting XML files are valid (no errors). Great work! :-)
You'll find source file with
$ grep -nr gimp-introduction-whats-new src/ src/introduction/whats-new.xml:9:
We use one po file per directory, so po/es/introduction.po contains all messages of src/introduction/*.xml, including the text of gimp-introduction-whats-new.html.
Ulf
Die Erfindung der Snde
war eine groe Snde
wider die Menschheit.
		-- Michael Schmidt-Salomon
gimp-docs-list mailing list
gimp-docs-list@gnome.org
Guiu Rocafort
2012-09-13 12:45:37 UTC (over 12 years ago)
Hi, after sending the patch I'm not able to do "git pull" anymore in the gimp-help-2 repository. The error it throws is the next:
"guiu@guiu-N50Vc:~/src/gimp-help-2$ git pull Updating 2817d87..0f50720
error: Your local changes to the following files would be overwritten by merge:
po/es/dialogs.po
po/es/filters/render.po
po/es/toolbox/transform.po
Please, commit your changes or stash them before you can merge. Aborting "
I've tried to stag the files using "git add " for every file it report problems, but I had no success with that. I'm sorry for annoying you with my newbie git problems.
Guiu Rocafort
Hey list !
I'm
$ grep -nr gimp-introduction-whats-new src/ src/introduction/whats-new.xml:9: ...
Ulf
-- Die Erfindung der Sünde
war eine große Sünde
-- Michael Schmidt-Salomon _______________________________________________ gimp-docs-list mailing list
*Please avoid sending me Word or PowerPoint attachments.
See http://www.gnu.org/philosophy/no-word-attachments.html*
Ulf-D. Ehlert
2012-09-13 20:27:46 UTC (over 12 years ago)
po/es/dialogs.po
You can try
1) git add po/es git commit -m "Your commit message" git pull --rebase
git format-patch -1 # not sure about the "-1" or
2) git diff > your_saved_changes.patch # paranoia... git stash
git pull
git stash apply # don't know: can this fail? git stash drop # only if "apply" succeeded or
3) git diff > your_saved_changes.patch git checkout po/es
git pull
patch -p1 < your_saved_changes.patch
If some command failes or something goes wrong, git prints an error message and usually a useful tip.
"git help " prints detailed infos about the specified git command ("man git-command" should do the same).
But note that I'm a git newbie too...
HTH, Ulf
Mitraut denen, die da sagen, dass Gott auf ihrer Seite steht.
Sie sind nur so nah ihrem Gott, weil sie so fern dem Menschen sind.
Julien Hardelin
2012-09-14 06:04:19 UTC (over 12 years ago)
Before git pulling, you must commit your changes to your local repository: /git commit -a -m "myCommit"/
You can also, if you don't want to accumulate commits, clean your sand box with
/git checkout /for every file./
/The file will return to its previous state, before your changes/./ Then git pull will update your file.
If you even though want to save you changes, you quand use /git stash/
Your files will be saved and then return to their previous state. Please run /man git-stash/ for more information about this command.
Julien
po/es/dialogs.po
Guiu Rocafort
