Problem with python save handler
9 of 9 messages available
Problem with python save handler Rob Antonishen 08 Sep 15:31
  Problem with python save handler Chris Mohler 08 Sep 16:09
   Problem with python save handler Rob Antonishen 08 Sep 16:48
    Problem with python save handler Rob Antonishen 09 Sep 15:00
     Problem with python save handler Chris Mohler 09 Sep 18:33
      Problem with python save handler Rob Antonishen 09 Sep 20:09
       Problem with python save handler Chris Mohler 10 Sep 00:33
       Problem with python save handler Joao S. O. Bueno 10 Sep 15:12
        Problem with python save handler Rob Antonishen 10 Sep 16:20
Rob Antonishen
2012-09-08 15:31:44 UTC (about 13 years ago)
I've put together a simple python save handler for OpenSCAD surface files.
It was working, but after making some changes it is no longer popping up a dialog and is failing to save. I can, however call it via the python console like pdb.file_openscad_save
The code is here: http://pastebin.com/EmpxmFVb
I am a python newb, so I suspect it might have something to do with bad syntax, but I get no errors when gimp starts up....
Can anyone suggest what dumb mistake I've made?
Thanks,
-Rob A>
Chris Mohler
2012-09-08 16:09:37 UTC (about 13 years ago)
Dunno if it's related but "min" and "max" are built-in functions, so you shouldn't use them for var names.
Chris
Rob Antonishen
2012-09-08 16:48:31 UTC (about 13 years ago)
Chris
Thanks I caught that and changed it, but still no luck http://pastebin.com/MKUEshcx
-Rob A>
Rob Antonishen
2012-09-09 15:00:53 UTC (about 13 years ago)
It seems the issue is related to adding extra parameters to the save handler....
Is it not possible to have dialog parameters with a python save handler?
-Rob A>
Chris
-Rob A>
Chris Mohler
2012-09-09 18:33:50 UTC (about 13 years ago)
Seems not, no. Setting the menu="" and/or setting the on_query causes your extra float parameters to always be set to "0.0", and there's no dialog. I can't tell if that's a bug, or by design.
This is a quick and dirty hack, but seems to work: http://pastebin.com/g1kriiqf
It ends up at the bottom of the File menu, instead of being properly registered as a save handler.
Chris
Rob Antonishen
2012-09-09 20:09:50 UTC (about 13 years ago)
Thanks Chris-
I'll just set the scaling to be 0-100 and let users deal with the scaling in the receiving application.
The odd thing is that I did manage to get a dialog showing up on the first save, then not on subsequent, the it stopped working completely, so I'm guessing there is a bug in there somewhere.
-Rob A>
Chris Mohler
2012-09-10 00:33:14 UTC (about 13 years ago)
Another workaround might be to pop up your own gtk window. There's a plug-in in the registry called "unseparate PNGS" that opens its own gtk dialog.
Chris
handler....
Thanks Chris-
-Rob A>
Joao S. O. Bueno
2012-09-10 15:12:52 UTC (about 13 years ago)
The openraster import/export plug-in ships with GIMP and should be used as an example to take off any doubts.
Check the code at: http://git.gnome.org/browse/gimp/tree/plug-ins/pygimp/plug-ins/file-openraster.py
(If, on the other hand, openraster import/export itself is not working, than something is broken, and we will have to fix it)
js ->
Thanks Chris-
-Rob A> _______________________________________________ gimp-developer-list mailing list
gimp-developer-list@gnome.org
Rob Antonishen
2012-09-10 16:20:38 UTC (about 13 years ago)
Thanks Joao-
I had looked at the ora handler as an example, but it does not use any additional parameters on the save.
-Rob A>
