Building html-es throws errors
Building html-es throws errors Guiu Rocafort 30 Aug 22:37
  Building html-es throws errors Ulf-D. Ehlert 31 Aug 10:28
Guiu Rocafort
2012-08-30 22:37:12 UTC (over 12 years ago)
Hi list !
I've made a fresh git clone of gimp-help-2. Then I made "./autogen --without-gimp" At this point I wanted to see the current state of the spanish manual, so I made a "make html-es"
It throws these errors: "
Makefile:483: xml/ca/.deps.mk: No such file or directory Makefile:483: xml/da/.deps.mk: No such file or directory Makefile:483: xml/de/.deps.mk: No such file or directory Makefile:483: xml/el/.deps.mk: No such file or directory Makefile:483: xml/en_GB/.deps.mk: No such file or directory Makefile:483: xml/es/.deps.mk: No such file or directory Makefile:483: xml/fi/.deps.mk: No such file or directory Makefile:483: xml/fr/.deps.mk: No such file or directory Makefile:483: xml/hr/.deps.mk: No such file or directory Makefile:483: xml/it/.deps.mk: No such file or directory Makefile:483: xml/ja/.deps.mk: No such file or directory Makefile:483: xml/ko/.deps.mk: No such file or directory Makefile:483: xml/lt/.deps.mk: No such file or directory Makefile:483: xml/nl/.deps.mk: No such file or directory Makefile:483: xml/nn/.deps.mk: No such file or directory Makefile:483: xml/pl/.deps.mk: No such file or directory Makefile:483: xml/pt_BR/.deps.mk: No such file or directory Makefile:483: xml/ru/.deps.mk: No such file or directory Makefile:483: xml/sl/.deps.mk: No such file or directory Makefile:483: xml/sv/.deps.mk: No such file or directory Makefile:483: xml/zh_CN/.deps.mk: No such file or directory "
Should I worry about that or I can go on translating the spanish documentation ?
Thank you
Guiu Rocafort
Ulf-D. Ehlert
2012-08-31 10:28:06 UTC (over 12 years ago)
You can safely ignore these warnings - I just don't know how to suppress them (the missing files are automatically created and then included by 'make').
Bye
Ulf
*Please avoid sending me Word or PowerPoint attachments. See http://www.gnu.org/philosophy/no-word-attachments.html*
+1 :)
Die Erfindung der Snde
war eine groe Snde
wider die Menschheit.
		-- Michael Schmidt-Salomon
gimp-docs-list mailing list
gimp-docs-list@gnome.org
