Meta-op XML
I talked a bit with pippin on IRC and I'm hoping that we can have a real
discussion (or at least shed a bit of light, for me) about how meta-op
deserialization should look from a conceptual stand-point (i.e. not the
specific XML format). The big thing is understanding the use-cases for XML
meta-ops. I see two distinct directions XML meta-ops could go:
1) The graph structure along with pad and property proxies is defined in
XML. Loading the XML returns a GeglNode with all this set up and that node
can then be used in a larger composition graph. XML files can contain just
a meta-op, or a composition which contains one or more regular operations
and meta-ops.
2) The XML defines a single meta-op with property and pad data and is
loaded into GEGL and registered via an API call so that new nodes can
subsequently be created with the meta-op name as the operation. The meta-op
transparently joins regular operations in GEGL's database.
In the first case, the meta-op XML definition would be a subset of the
regular graph serialization/deserialization code. I'm starting to get the
impression that the latter case is the desired one. Is the plan to move
existing operations such as drop-shadow from C to an XML description?
Should XML meta-ops be loaded by GEGL at startup along with compiled C
operations (in shared object format) from GEGL_PATH? If this is the case,
then I can see that the meta-op XML spec is distinct from the composition
spec outside of the future-possibility of embedded anonymous meta-ops.
Compositions may also reference XML meta-ops by filename so that they are
loaded at the same time that the composition is loaded, but compositions
and meta-ops have otherwise separete deserialization. How am I doing? What
is the expectation as to how meta-op XML loading will look and work?
