Purple fringing removal extension
12 of 12 messages available
Purple fringing removal extension Martin Jambon 14 Jul 08:35
  Purple fringing removal extension Monty Montgomery 14 Jul 20:51
   Purple fringing removal extension Martin Jambon 15 Jul 07:17
  Purple fringing removal extension Alexandre Prokoudine 14 Jul 21:19
   Purple fringing removal extension Robert Krawitz 14 Jul 22:51
    Purple fringing removal extension wwp 15 Jul 07:05
    Purple fringing removal extension Alexandre Prokoudine 16 Jul 08:37
   Purple fringing removal extension Robert Krawitz 14 Jul 22:56
    Purple fringing removal extension Martin Jambon 15 Jul 07:52
    Purple fringing removal extension Martin Jambon 15 Jul 07:54
     Purple fringing removal extension Robert Krawitz 15 Jul 15:14
      Purple fringing removal extension Martin Jambon 16 Jul 07:49
Martin Jambon
2012-07-14 08:35:21 UTC (over 13 years ago)
I am totally new here but I wrote a standalone program that does a decent job of removing purple fringing from photos, and I would like to be able to implement the same functionality for Gimp.
Here are some examples of what it does:
http://mjambon.com/purple-fringe/examples.html
My algorithm needs to perform pixelwise operations (+, -, min, max between two channels; scaling of one channel) but I also would prefer something that is easy to install (for users) and easy to maintain (for me).
The OCaml source code is here; it should give an idea of what's needed:
https://github.com/mjambon/purple-fringe/blob/master/src/unpurple.ml
(see functions make_purple_blur and remove_purple_blur, lines 103-177)
My questions are:
1. Is it possible to do that using a Gimp script?
2. If so, Scheme or Python?
3. If a plugin makes more sense, will average users be able to install it for themselves or would I have to wait for the inclusion in some standard precompiled distribution?
Also, please let me know if you're interested in the tool or if you know something that is already usable from within Gimp. The results obtained with Darla's purple fringe script
(http://www.farcrydesign.com/GIMP/PurpleFringe.html) were too disapppointing, and my recent camera's built-in chromatic aberration correction doesn't do much either (Sony NEX-5N).
Any sort of help is appreciated!
Thanks,
Martin
Monty Montgomery
2012-07-14 20:51:11 UTC (over 13 years ago)
Hey, that's not half bad. I especially like that it doesn't go overboard trying to 'fix' everything completely, just makes a nice solid improvement.
Do you have any examples that show it not working well, or doing something unexpected? For example, a camera where the fringing is a slightly different hue due to a slightly different Bayer filter, or a different UV cutoff?
I would Totally Use This, especially given my fondness for vintage lenses that can fringe badly.
Monty
2012-07-14 21:19:52 UTC (over 13 years ago)
My questions are:
Just in case, are you aware of http://kcd.sourceforge.net/fix-ca.php ?
Robert Krawitz
2012-07-14 22:51:15 UTC (over 13 years ago)
My questions are:
That fixes lateral chromatic aberration (the focal length, or image magnification, is different for different wavelengths but the focal plane is the same). Purple fringing is caused by longitudinal chromatic aberration (the focal plane is different for different wavelengths). It's a different lens defect and is much more difficult to fix (stopping down reduces the problem, since it increases depth of field, but there are often reasons why you don't want to do that).
Lateral chromatic aberration will be zero at the center of the image and will increase toward the edges; longitudinal chromatic aberration will affect the entire image field (including the very center) more or less equally.
Martin's tool looks very impressive, particularly for those of us who have the Canon 85 f/1.8 -- a truly great lens marred only by a fair bit of purple fringing at large apertures.
Robert Krawitz
2012-07-14 22:56:57 UTC (over 13 years ago)
My questions are:
BTW, Martin, I'd suggest optimizing it -- 1 second/megapixel is a fair amount of time for someone processing a lot of 18 MP images, and people with Nikon D800's will be even more unhappy. You may also want to talk with the ImageMagick folks about getting it included there. This could become a very important part of a photographic workflow.
wwp
2012-07-15 07:05:46 UTC (over 13 years ago)
Hello Robert,
My algorithm needs to perform pixelwise operations (+, -, min, max between two channels; scaling of one channel) but I also would prefer something that is easy to install (for users) and easy to maintain (fo> >> The OCaml source code is here; it should give an idea of what's needed:
My questions are:
I second that, his work is impressive!
wwp
Martin Jambon
2012-07-15 07:17:46 UTC (over 13 years ago)
It requires manual tuning when purple objects are present, otherwise the default settings would often grey them out. The purple areas in the last example at http://mjambon.com/purple-fringe/examples.html would become completely black with the default settings.
I am sure there are many ways to improve the results but before digging deeper, which can last forever, I would like to create an initial Gimp extension.
Good to hear!
Martin
Martin Jambon
2012-07-15 07:52:13 UTC (over 13 years ago)
My questions are:
Right. I'd like to try built-in implementations of blur algorithms first, since it is likely to remain the bottleneck of my algorithm. If that's not enough, some parallelization should help.
Martin
Martin Jambon
2012-07-15 07:54:50 UTC (over 13 years ago)
My questions are:
Martin
Robert Krawitz
2012-07-15 15:14:13 UTC (over 13 years ago)
My questions are:
Have you profiled the code yet?
Martin Jambon
2012-07-16 07:49:31 UTC (over 13 years ago)
My questions are:
Yes, but it's written in OCaml and I expect to rewrite it completely in order to fit in the gimp dev environment. The algorithm is not very complicated and I'm hoping to use optimized high-level primitives.
Martin
2012-07-16 08:37:25 UTC (over 13 years ago)
Aha, thanks for clarification! :)
@Martin
That would be C and, preferably, as a GEGL operation :)
