Multiply blend mode in GIMP
Multiply blend mode in GIMP Calculemus 09 Jul 19:21
  Multiply blend mode in GIMP Michael Henning 09 Jul 19:39
  Multiply blend mode in GIMP Simon Budig 09 Jul 20:35
   Multiply blend mode in GIMP Calculemus 09 Jul 21:50
    Multiply blend mode in GIMP Calculemus 09 Jul 23:40
  Multiply blend mode in GIMP Richard Gitschlag 10 Jul 15:00
Calculemus
2012-07-09 19:21:46 UTC (almost 13 years ago)
I am reading this: docs.gimp.org/en/gimp-concepts-layer-modes.html
and I wonder why is the formula for "Multiply", E = (M * I) / 255?
Why divide with 255, that is the part that confuses me. Should it not be just M * I and then clamp the result in range 0 to 255?
Thanks
Michael Henning
2012-07-09 19:39:27 UTC (almost 13 years ago)
Each pixel component has a value somewhere between 0 and 255. When you multiply two together, it will have a value somewhere between 0 and 65,025 (255 squared). You need to divide by 255 so that maximum value gets scaled back down to 255 (If you simply clamp it, the majority of your pixels will be white).
Of course, when working with doubles or floats, 1.0 is normally the maximum (Non-HDR) value, so no division is needed.
Hopefully that clears things up. -- drawoc
Thanks
gimp-developer-list@gnome.org
Simon Budig
2012-07-09 20:35:15 UTC (almost 13 years ago)
for 8 bit modes 255 is equivalent to the value 1.0. So the proper formula would be
E = (M/255 * I/255) * 255.
I guess you can see how the other formula happens then :-)
Bye, Simon
Calculemus
2012-07-09 21:50:19 UTC (almost 13 years ago)
Oh, I see now, thanks!
What about divide? E = (256*I) / (M+1)
This can produce weird values. What if I = 255 and M = 0. Then we have 256 * 255 / 1 = 65 280 and that does not make sense.
Calculemus
2012-07-09 23:40:28 UTC (almost 13 years ago)
Another confusing blend mode is Overlay.
I have found 4 sources that have one definition for Overlay, and GIMP uses another one, I am confused.
1. The official Adobe reference version 1.7 chapter 7.2.4 2. http://www.gegl.org/operations.html#op_svg:overlay 3. https://dvcs.w3.org/hg/FXTF/rawfile/tip/compositing/index.html#blending 4. http://www.pegtop.net/delphi/articles/blendmodes/overlay.htm
Thanks
Richard Gitschlag
2012-07-10 15:00:08 UTC (almost 13 years ago)
Date: Mon, 9 Jul 2012 21:21:46 +0200 From: calculemus1988@gmail.com
Subject: [Gimp-developer] Multiply blend mode in GIMP
Thanks
Other people have answered it already, but an alternate way of looking at the Multiply formula is:
E = M * (I / 255)
...or...
E = (M/255) * I
Where M (the multiply layer) values are expressed in a 0...255 range, therefore, (M/255) yields a 0-1.0 percentage and that is exactly the behavior we need.
The documentation could probably be phrased just a little better.
-- Stratadrake
strata_ranger@hotmail.com
