Proposal: tool-preset thumbnails/icons.
Proposal: tool-preset thumbnails/icons. T Hall 07 Jul 15:57
  Proposal: tool-preset thumbnails/icons. Alexia Death 09 Jul 13:27
T Hall
2012-07-07 15:57:40 UTC (almost 13 years ago)
Please consider the following feature suggestion.
I propose to allow each tool preset to be assigned a small custom thumbnail image (by the creator of the preset/the user) in place of the current tool icon. The purpose of this image would be as follows: 1. To make presets easily recognisable at a glance. 2. To make if possible to display presets in a grid (i.e. without names, just thumbnails). This would allow more presets to be visible and selectable in the Tool Presets dockable dialog, without it taking up the entire dock area.
I suggest these thumbnails could be created either by loading/pasting an image, or painting directly onto a small canvas available via the Edit Tool Preset dialog.
Note:
1. You can already select an icon from a list. However, none of these icons are particularly suited to distinguishing presets. 2. If the type of tool is considered important, a much smaller version of the current tool icon could be added in the corner of the thumbnail. (Currently, selecting a different icon hides the preset type, so presumably this is not a concern) 3. The current tool preset icons don't actually seem to be the right size (they are pixellated), which makes me wonder if they are just standing in for a larger image that whoever wrote the Tool Presets dialog expected to have.
4. Most of these suggestions could also apply to Paint Dynamics items.
Regards, T. Hall
Alexia Death
2012-07-09 13:27:40 UTC (almost 13 years ago)
Both of these suggestions were in the inital plan for tool presets and are dependent of each other, they just havent been implemented yet.
