suggestions
suggestions wanderer 25 Jun 04:22
  suggestions Alexandre Prokoudine 25 Jun 04:43
   suggestions Srihari Sriraman 25 Jun 14:03
suggestions free 26 Jun 11:11
wanderer
2012-06-25 04:22:20 UTC (almost 13 years ago)
suggestions
Hello!
I'm new here, so first of all I would like to say it's a wonderful job that has been done in 2.8. Knowing a little bit of programming, I thought I might help with minor improvements to the software.
So, I came up with these little improvements to Gimp that would make it better, in my own point of view. I would like to share these suggestions to you, to see if they are really relevant. And I ask for your pardon if I am writing things that have already been discussed.
Here are the suggestions:
1- When you are using the scale or rotate tool and try to insert a guide, it doesn't close the tool.
2- add the option to snap guides at the border and/or center of layers bounds.
3 - add the option to autocrop layers to their limits (the same thing like when you do 'alpha to selection' then 'layers -> crop to selection') whenever you change it.
4 - add a checkbox button in the scale tool for scale from center. Maybe add also a keyboard shortcut for it.
For the fourth suggestion I saw an entry in bug list, where a complete system of anchor for scale was intended to be made. So this could be an temporary fix for something I think it's important. I know that you can scale from center using layer->scale layer, but I though "why scale tool don't do it?"
Also, as I said before, if you think any of the suggestions are good ones I could try to implement them myself. But I am really new here, so I think I would have to understand the code and the development proccess first. I could make it a plug-in or script, but if I am going to code it and it's relevant, I thought I might do it directly to the source code of the program. And, of course, it would be a great honor to contribute with a software and philosophy that I admire.
Thanks for the attention!
freewanderer
2012-06-25 04:43:55 UTC (almost 13 years ago)
suggestions
You mean, the suggestion is to _not_ close thew tool? :)
Makes sense to me
To autocrop in which cases? Transformation tools already have that.
This is already in works and will be available in the new unified transform tool, except it will be called differently. See http://gui.gimp.org/index.php/Transformation_tool_specification#pivot for reference.
Srihari Sriraman
2012-06-25 14:03:56 UTC (almost 13 years ago)
suggestions
Relative snapping/positioning has been on my mind a lot! A lot of times when making banners or brochures, I just want one layer aligned at the same horizontal or vertical position or with same height or width. I don't need grids or any guides. In many of my designs, only the relative positioning of layers matters.
Currently, I do this by creating guides and then snapping both layers to it, appropriately. This is quite strenuous to repeat every time I need such a facility.
How about "*snap to layer edges*", which creates guides at all 4 edges of all layers. (See [1] )
These "Layer-Guides" could be in a different colour to differentiate from user-defined guides.
Could also configure which edges we would like to snap to.
If these Layer-Guides get visually confusing with other guides and the grid, then we can display the guide(s) momentarily when a layer is scaled or moved to snap to it(them). That is, show the guides only *during the snap *.
[1] https://dl.dropbox.com/u/28366148/relative-guides.jpg
On Mon, Jun 25, 2012 at 10:13 AM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
guide, it
Makes sense to me
like
add
gimp-developer-list@gnome.org
free
2012-06-26 11:11:32 UTC (almost 13 years ago)
suggestions
Yes, that's it! I thought that could work well with my other suggestion, snapping the guides to the layer edges or center.
2-How about "*snap to layer edges*", which creates guides at all 4 edges of all layers. (See [1] )
Well, I thought of something that would not create guides... I know that there is an option to create guides in all 4 corners of the layer. I thinking in something that would not create the guides, rather give the ability for the user to snap in the corner he/she wishes.
Well, I was thinking in something like this: If this option is enabled, the layer bounds will be the entire image if there is nothing on it. If there is a brush stroke, painting, or anything in the layer, immediatly after that gimp automatically crop the layer bounds to the limits of the brush stroke/painting or whatever. I am thinking in the behaviour of layers in photoshop, to be honest.
Good to know it! Can't wait to see it done.
Thanks for the answers! I think the snap to layer border may be a good implementation. I will try to do the coding.
freewanderer
