Fwd: Re: present xcf as what it is, a gimp project file format
Fwd: Re: present xcf as what it is, a gimp project file format gg 16 Jun 21:07
gg
2012-06-16 21:07:56 UTC (almost 13 years ago)
-------- Original Message -------- Subject: Re: [Gimp-developer] present xcf as what it is, a gimp project file format
Date: Sat, 16 Jun 2012 16:58:52 -0400 From: Nicolas Robidoux
To: gg
You realize you only replied to me?
Opps, wrong button, Thanks. ;)
On Sat, Jun 16, 2012 at 1:56 PM, gg wrote:
On 06/16/12 18:54, Nicolas Robidoux wrote:
- to really Save the contents of the file has to match what is on the screen (save, quit, restart, open file: no change--undo history excepted). this is not just a good idea, this is the law. breaking the law: usability blooper.
Indeed, if "Save is lossless" is a law, "Save" has to be to XCF, and something else has to be used to "save" to any other format.
Nonetheless, I can't help but think that few people would buy a gun that makes it hard to shoot yourself in the foot.
No matter how sensical the feature.
Because most of us like to shoot first and ask questions later.
Most of use like to be treated like intelligent beings, not being forced or told how we "should" be working.
How many "top level" marksmen would want a gun that only did what the designer thought was "safe" ?
There are no laws. GUI design does not come down from Mt Sinai on blocks of stone. If the spec does not work in some way it may need to be changed. That is what is being discussed.
/gg
