JPEG lossless operations?
7 of 7 messages available
JPEG lossless operations? gfxuser 27 May 18:26
  JPEG lossless operations? Ofnuts 27 May 19:05
   JPEG lossless operations? Nicolas Robidoux 27 May 19:28
   JPEG lossless operations? gfxuser 27 May 19:31
    JPEG lossless operations? Bruce 30 May 15:55
     JPEG lossless operations? Ofnuts 30 May 23:04
      JPEG lossless operations? Liam R E Quin 30 May 23:18
gfxuser
2012-05-27 18:26:45 UTC (almost 13 years ago)
reading some of the JPEG related articles here I wondered whether GIMP or GEGL can do lossless rotation and cropping on JPEG images. Can you tell me more about it?
Thanks, grafxuser
2012-05-27 19:05:28 UTC (almost 13 years ago)
Thanks, grafxuser
For rotation, that would only work on images with dimensions that are a multiple of 8. For cropping, that only works if you crop on 8-pixel boundaries from the origin corner.
Otherwise, this also assumes that JPEG is an "editable format", while the recent kerfuffle around the Export function has demonstrated that it is not, in the current vision.
Nicolas Robidoux
2012-05-27 19:28:36 UTC (almost 13 years ago)
For a non GIMP solution (with severe constraints on the rotation and cropping parameters, as is pretty much unavoidable): http://jpegclub.org/
gfxuser
2012-05-27 19:31:15 UTC (almost 13 years ago)
Thanks, grafxuser
Thanks, Ofnuts.
Yes, 'Export vs. Save' was a long discussion and I don't want to boost it again. Although it takes a little getting used to I can live with the new behaviour. Despite of that I sometimes wondered in the past whether GIMP will introduce new compression artifacts if I rotated or cropped an existing JPEG image (yes, there are some cameras where saving in JPEG of sufficient quality is the best choice. Shall we not use them anymore?).
Best regards,
grafxuser
Bruce
2012-05-30 15:55:36 UTC (almost 13 years ago)
I've read that Picasa (Google's program) might be able to perform lossless rotations, but I'm just going by what I've read. (Source
Apparently there are ways to test if the tool you use makes use of lossless rotation. This page lists some:
http://www.impulseadventure.com/photo/lossless-rotation-test.html
This page also has a nice explanation of lossless rotation and its finer nuances:
http://www.betterjpeg.com/lossless-rotation.htm
From what I've learned so far, I think in the end you just have to relax about all this stuff and not worry about it too much, though it does help to know what's happening when you do certain things (such as rotate a jpeg).
Thanks,
grafxuser
Thanks, Ofnuts.
Best regards,
grafxuser
______________________________**_________________ gimp-developer-list mailing list
gimp-developer-list@gnome.org
https://mail.gnome.org/**mailman/listinfo/gimp-**developer-list
2012-05-30 23:04:26 UTC (almost 13 years ago)
On 05/30/2012 05:55 PM, Bruce wrote:
I've read that Picasa (Google's program) might be able to perform lossless rotations, but I'm just going by what I've read. (Source )
Apparently there are ways to test if the tool you use makes use of lossless rotation. This page lists some: http://www.impulseadventure.com/photo/lossless-rotation-test.html
The best (and fastest....) way to rotate a JPEG is to change its orientation flag...
Liam R E Quin
2012-05-30 23:18:23 UTC (almost 13 years ago)
Not all programs honour the orientation flag.
Windows Explorer's thumbnails used to be an example, don't know if that's still true in Windows 7.
Liam
