Save defaults not working?
Save defaults not working? Guillermo Espertino (Gez) 12 May 12:20
  Save defaults not working? Jernej Simončič 12 May 18:59
2012-05-12 12:20:02 UTC (almost 13 years ago)
Hi:
I just noticed that the function for saving defaults for the jpeg export plugin isn't working in 2.8
Am I missing something or should I file a bug report?
btw, new jpeg defaults are much, much better than 2.6s but imo the progressive option shouldn't be on. It makes the file size a tad larger and it isn't always needed. Is there any special reason for using that option as default?
Gez.
Jernej Simončič
2012-05-12 18:59:30 UTC (almost 13 years ago)
In my experience, the majority of images become smaller when you save them as progressive.
