Gimp-gap in GIMP 2.8
7 of 7 messages available
Gimp-gap in GIMP 2.8 Daniel Pinheiro Lima 11 May 23:55
  Gimp-gap in GIMP 2.8 Joao S. O. Bueno 12 May 04:34
  Gimp-gap in GIMP 2.8 Alexandre Prokoudine 12 May 05:40
  Gimp-gap in GIMP 2.8 Daniel Pinheiro Lima 16 May 22:16
   Gimp-gap in GIMP 2.8 Daniel Pinheiro Lima 28 Jun 14:33
    Gimp-gap in GIMP 2.8 Daniel Pinheiro Lima 29 Jun 04:44
     Gimp-gap in GIMP 2.8 Daniel Pinheiro Lima 30 Jun 14:08
2012-05-11 23:55:06 UTC (almost 13 years ago)
Hi developing people.
First of all, congratulations for the excelent work in gimp 2.8. The software is amazing. Better than never. Now for the business. I'm working in an animation/comics, called The Detail Library project, since 2007 and we use Gimp with GAP to everything. So I was wondering:
When we can get the GIMP-GAP for 2.8, if exist someone working on it, and even if (in the case of be an abandoned project) if exist some way to obtain the same resources in gimp. Can someone please help (with information, since we can still use gimp 2.6 for a while)
The most used features in our project are:
The "Next/Previous image", it makes fast the edition of multiple images, is better tha the tabs in sligle windowed mode. The Playback feature (crucial to animation). For pencil test is more precise than the actual "playback in the filter menus The "Modifier Layers" I belive the "BIMP" (Batch Image Manipulator) can replace it.
The "Covert", according to the new export/save behavior must be adapted to a "export multiple files"
So we are looking for this resources in gimp 2.8, any info about willb very helpful
Thanks a lot and soory for the "caveman's english"
Daniel Lima ---
http://oswaldoaugusto.com
Joao S. O. Bueno
2012-05-12 04:34:43 UTC (almost 13 years ago)
Hi Daniel -
what specifically is not working in GIMP-GAP iin GIMP 2.8?
Since a grea deal of exfort is put in GIMP in order not to break plug-in API's, regular GIMP-GAP shoud just work on GIMP 2.8, and if not, it culd be reported as a bug on GIMP itself.
However, you might find it easier to get a pre-compiled version of GIMP-GAP for your platform - GIMP-GAP,a s GIMP itself is developed and presented in source code only - whoever packaged GIMP-GAP for your GIMP 2.6 should make a release with binaries for GIMP 2.8 as well - or you might simply build GIMP-GAP yourself from teh tarball. Actually, I think even the same binaries could work - have you simply tried copying the files from the plug-ins directory of gimp-2.6 to gimp 2.8 ?
js
Daniel Lima ---
gimp-developer-list@gnome.org
2012-05-12 05:40:11 UTC (almost 13 years ago)
When Wolfgang adapts it to the new API.
People don't do time schedules round here :)
2012-05-16 22:16:20 UTC (almost 13 years ago)
I just want to say that everything works just fine in the *ppa:otto- kesselgulasch/gimp all resources I've checked in GAP are working properly.
Thank you Alexandre and João for the quick answer and thanks everyone in the gimp devel.
2012/5/11 Daniel Pinheiro Lima
Daniel Lima ---
http://oswaldoaugusto.com/
2012-06-28 14:33:15 UTC (almost 13 years ago)
Hi folks,
Sorry to come back to this again, but now i've got a problem! Not everything is working fine with gimp-gap. i belive that i have found one bug. In the "frames modify" i can't access the "function" options. The only avaiable is the "Set Layer Visible".
I'm using GIMP 2.8 from the ppa:otto-kesselgulash (ubuntu 12.04)
Thanks Daniel
2012/5/16 Daniel Pinheiro Lima
Daniel Lima ---
2012-06-29 04:44:43 UTC (almost 13 years ago)
Solved! Just forgot how unity places everything on the top bar! Sorry!
Thanks anyway!
2012/6/28 Daniel Pinheiro Lima
Hi folks,
Thanks Daniel
Daniel Lima ---
2012-06-30 14:08:08 UTC (almost 13 years ago)
Just for the record (or, how I've solve the problem), I've found a very nice solution to use GIMP in the "multiple window" mode inside the UNITY (ubuntu 12.04) enviroment. Is just run the GIMP with the command:
in terminal:
UBUNTU_MENUPROXY= gimp (That will place the menus in the windows instead of the top bar)
OR APPMENU_DISPLAY_BOTH=1 gimp
(that will place the menus both in the top bar and in the windows)
via ALT+F2:
env UBUNTU_MENUPROXY= gimp
env APPMENU_DISPLAY_BOTH=1 gimp
Or make a "gimp.desktop" file with an text editor and place in the launcher:
[Desktop Entry] Version=2.6.12
Type=Application
Terminal=false
Exec= env APPMENU_DISPLAY_BOTH=1 gimp Name=Gimp
GenericName=Gimp Painter
Icon=/usr/share/icons/hicolor/scalable/apps/gimp.svg
thanks, Udan
2012/6/29 Daniel Pinheiro Lima :
Thanks anyway!
Hi folks,
Thanks Daniel
I just want to say that everything works just fine in the ppa:otto-kesselgulasch/gimp all resources I've checked in GAP are working properly.
Thank you Alexandre and Joo for the quick answer and thanks everyone in the gimp devel.
Daniel Lima ---
