Python-fu: difference between PF_FILE and PF_FILENAME, and how to ask for a file name to *create*
2011-11-13 21:44:21 UTC (about 13 years ago)
I'm writing a python plugin that saves things to a file, and I'm trying to come up with the right parameter type to obtain a filename form the user.
There are PF_FILE and PF_FILENAME parameter types. Both correspond to a string with the file name in it. Furthermore the file must exist for both, so they cannot be used for the name of a file to be created? Why are there two types if they do the same thing? Am I missing something?
Jerry Baker
2011-11-14 12:32:48 UTC (about 13 years ago)
PF_FILENAME: Only allows the user to choose a file. PF_DIRNAME: Only allows the user to choose a directory.
PF_FILE: Allows the user to choose a file or a directory depending on what your default string is.
If you put a '/' at the end of the default string it will prompt the user for a directory.
If you leave off the '/' at the end of the default string it will prompt the user for a file.
Examples: (PF_FILE, "pf_afile", _("Choose File:"), "/home/jbaker"), # Choose a file
(PF_FILE, "pf_adir", _("Choose Directory:"), "/home/jbaker/"), # Choose a directory
or
(PF_FILE, "pf_afile", _("Choose File:"), ""), (PF_FILE, "pf_adir", _("Choose Directory:"), "/"),
-----Original Message----- From: Ofnuts
Subject: [Gimp-developer] Python-fu: difference between PF_FILE and PF_FILENAME, and how to ask for a file name to *create* Date: Sun, 13 Nov 2011 22:44:21 +0100
2011-11-14 20:53:25 UTC (about 13 years ago)
OK, makes sense. Now, how can I prompt for the name of a file that doesn't exist (yet)?
or
-----Original Message----- *From*: Ofnuts >
*To*: gimp-developer-list@gnome.org > *Subject*: [Gimp-developer] Python-fu: difference between PF_FILE and PF_FILENAME, and how to ask for a file name to *create* *Date*: Sun, 13 Nov 2011 22:44:21 +0100
Jerry Baker
2011-11-15 11:44:36 UTC (about 13 years ago)
The only way that I know of is to use a widget for the directory and one for the file, then os.path.join them...
import os
from gimpfu import *
gettext.install("gimp20-python", gimp.locale_directory, unicode=True)
def jbtest(project_directory, new_file):
final_str = "Test Text..."
output_file = open(os.path.join(project_directory, new_file), 'w') output_file.write(final_str)
output_file.close()
register( "jbtest",
N_("Choose a Directory and Filename:"), "Create a new file in the specified directory", "Jerry Baker",
"Jerry Baker",
"11/14/2011",
N_("jbtest"),
# --- Parameters
(PF_DIRNAME, "project_directory", _("Project Directory:"), ""), (PF_STRING, "new_file", _("File Name:"), _("new_file.txt")), ],
# --- Results
jbtest,
menu="/_Dev",
domain=("gimp20-python", gimp.locale_directory) )
main()
Cc: gimp-developer-list@gnome.org
Subject: Re: [Gimp-developer] Python-fu: difference between PF_FILE and PF_FILENAME, and how to ask for a file name to *create* Date: Mon, 14 Nov 2011 21:53:25 +0100
or
