Finding out what happens when compositing layers
7 of 7 messages available
Finding out what happens when compositing layers Ofnuts 15 Sep 21:39
  Finding out what happens when compositing layers David Gowers (kampu) 16 Sep 00:20
   Finding out what happens when compositing layers Ofnuts 16 Sep 23:06
    Finding out what happens when compositing layers David Gowers (kampu) 17 Sep 03:43
Finding out what happens when compositing layers 17 Sep 04:31
  Finding out what happens when compositing layers 17 Sep 04:37
  Finding out what happens when compositing layers Patrick Horgan 17 Sep 16:18
2011-09-15 21:39:29 UTC (over 13 years ago)
I'll trying to find out what happens when a layer is in subtract mode with a global opacity not one or zero (i.e. what computations are done with the pixels values of the composite image of the layers below, the pixel values of the layer, and the general opacity). I have a git extract of the Gimp source code (and of gegl & babl) but got lost... Can someone help?
2011-09-16 00:20:56 UTC (over 13 years ago)
In GEGL, the layer mode code is autogenerated from formula strings -- see operations/generated/math.rb
The opacity behaviour is not documented there, but my understanding is that the alpha of the underlying composite is preserved, and opacity only effects how much of the layer's COLOR channels are applied (per the standard blending formula).
2011-09-16 23:06:37 UTC (over 13 years ago)
someone help?
Well, I know that in "Normal" mode, I have in each RGB channel:
Composite=Over*alpha+Under(1-alpha)
(assuming "Under" is fully opaque), but in Subtract mode, I would have several possibilities
Composite=Under(1-alpha)-Over*alpha or
Composite=Under(1-alpha)+(1-Over)*alpha or
Composite=Under(1-alpha)+(1-Over*alpha)
and $deity knows what else.
math.rb isn't taking the opacity in account (but is an interesting read...)
Thx.
2011-09-17 03:43:22 UTC (over 13 years ago)
No, you just subtract Over from Under with no multiplication, then you
perform a RGB (not RGBA) Composite of the result and Under, to produce the final composite.
2011-09-17 04:31:45 UTC (over 13 years ago)
I came across this quite some time ago: http://www.simpelfilter.de/en/basics/mixmods.html
2011-09-17 04:37:21 UTC (over 13 years ago)
PS: I thought I had type in my word before I send the mail. I did not know what had happened. Sorry to everybody for the spam and wish this mail is all right.
Patrick Horgan
2011-09-17 16:18:27 UTC (over 13 years ago)
That's wonderful! Even mentions GIMP a bit.
Patrick
