UPDATING VERSIONS
UPDATING VERSIONS "Andr 20 May 14:06
  UPDATING VERSIONS Alexandre Prokoudine 20 May 14:11
   UPDATING VERSIONS Jernej Simončič 20 May 17:38
"Andr
2011-05-20 14:06:01 UTC (almost 14 years ago)
UPDATING VERSIONS
I am currently uses GIMP 2.4.7, and I see that the current version is 2.6.11.
How do I go about my version of GIMP? Should I UNINSTALL the previous version first and then install the newer version, or will installing the newer version simply overwrite the previous version if I don't uninstall it first?
----- ANDRÉ STRYDOM MMus, LTCL
2210 West 35th Avenue
Pine Bluff, AR 71603-5753
United States of America
Telephone & Fax: (870) 535-8683
Cellular: (870) 489-3588
EMail: maestro1@cablelynx.com
2011-05-20 14:11:35 UTC (almost 14 years ago)
UPDATING VERSIONS
It's usually best to uninstall previous version first. All the add-ons you installed yourself should be automatically picked by a new one.
P.S. Please use gimp-user@ mailing list for such questions in the future.
Gimp-developer mailing list
Jernej Simončič
2011-05-20 17:38:00 UTC (almost 14 years ago)
UPDATING VERSIONS
Not on Windows - just install over the old one.
