Announcing Gimpscripter plugin authoring tool, beta prototype
Announcing Gimpscripter plugin authoring tool, beta prototype lloyd konneker 09 May 13:23
  Announcing Gimpscripter plugin authoring tool, beta prototype Tim Chen 10 May 02:40
  Announcing Gimpscripter plugin authoring tool, beta prototype Sven Neumann 10 May 07:37
Announcing Gimpscripter plugin authoring tool, beta prototype lloyd konneker 10 May 13:19
lloyd konneker
2011-05-09 13:23:18 UTC (almost 14 years ago)
Announcing a new version of the "Make Shortcut" plugin, now called "GimpScripter". It lets you point-and-click create a plugin that calls a sequence of plugins, PDB procedures, or macros. It is a plugin authoring tool.
Gimpscripter is a Gimp plugin written in Python. It generates Python code for a plugin.
The source is at github.com/bootchk/gimpscripter. Installation instruction are in the README file. The source includes many readable documents such as NEWS, TODO, and a user's manual. You can download a tarball or zip there. It is in Python so just install it in the standard Gimp directory for plugins, no compilation necessary.
Gimpscripter is still in development. It usually works, but is incomplete and could be improved.
Take a look if you are interested in scripting Gimp, as a user or as a programmer.
Gimpscripter lets you visually (graphically, point-and-click) implement a sequential recipe, for example "Choose this, set that parameter, choose that, ..". It doesn't have any control flow statements.
It uses a stack model: it hides a prefix of parameters and references them to active objects.
It includes a macro facility and macros for common sequences of operations, and to wrap certain PDB procedures with higher-level parameter type, e.g. PF_BRUSH instead of PF_STRING for a brush.
Some people suggest using a recorder/playback tool to automate Gimp. Scripts from such tools break when the Gimp GUI changes, and the scripts are not easily distributable. Gimpscripter is an alternative.
Gimpscripter does have many weaknesses, some of which can be attributed to lack of support from the PDB. So it could help guide improvements to the PDB (but it might not raise any issues not already known, such as not storing defaults.)
I welcome comments or contributions.
Here is an example use, to make a plugin "Stroke selection with selection":
Choose "Filter/Gimpscripter" to start Gimpscripter.
From the menu pane choose "Edit/Copy".
Choose "Edit/Paste as/New Brush". Choose "Select/To path".
Choose "Edit/Stroke/Path".
Enter a name for the plugin, for example "Stroke selection with selection".
Choose the OK button.
Read the summary and choose the OK button. Restart Gimp.
Open an image and make a selection.
Choose "Shortcuts/Stroke selection with selection". You should see a mobius like effect.
Tim Chen
2011-05-10 02:40:16 UTC (almost 14 years ago)
Looks good. The UI for creating macros could use some improvement though, especially some options to remove/insert actions into existed scripts. Maybe you can reference Michael Terry's recent work on Adaptable GIMP.
http://adaptablegimp.org/index.php/How_to_Create_a_Task_Set
Thanks for sharing.
Regards, Tim Chen
http://ht-timchen.org
2011-05-10 07:37:33 UTC (almost 14 years ago)
Sounds great. You should consider to name it GIMPScripter or similar though as GIMP is called GIMP and not Gimp.
It's a pity that GIMP needs to be restarted. We should add API to (re)load all or a particular plug-in at run-time.
lloyd konneker
2011-05-10 13:19:35 UTC (almost 14 years ago)
Yes, the Gimpscripter UI and the whole app is thin and could be improved. But thanks for your suggestion, it helps to prioritize.
Thanks for the link, AdaptableGimp is exciting.
I haven't yet fully explored AdaptableGimp, so what follows are first impressions. AdaptableGimp seems to be a social way to document a TaskSet (what I call a recipe) and to make the TaskSet point-and-clickable. The difference is that TaskSets are not executable as a unit, you still must point and click. This makes sense when the user needs to use the mouse/pointer during the task, e.g. to make a selection or to draw a shape. OTOH when no user mouse/pointer interaction is required, why not make a TaskSet executable? Shouldn't we merge the two ideas of social programming, and point-and-click authoring of executable-as-a-unit recipes? Maybe the users don't want the messiness: "just give me a recipe, I can execute it myself, all that talk about active objects and stacks is confusing."
And GEGL is part of the picture, a sequence of image transformations that can be executed as a unit, and controlled as a unit (I have a superficial understanding of GEGL.)
Many have suggested improvements to Gimp Registry, to make it more sociable: easier to find, upload, download, and manage plugins.
SociableGimp: on-line, community TaskSets AND plugins?
Some terminology clarification: Gimpscripter creates what I call shortcuts or wrapper plugins. They are distributable, first-class plugins. They should be sociable. What I call macros are not easily distributable. They are short code fragments built-into Gimpscripter. They are a layer on top of the PDB, to adapt it (eventually some of the macros might migrate to, or be fixed in, the PDB?) They adapt the model presented by the GIMP GUI (e.g. a new layer is in an image) to the model presented by the PDB (e.g., a new layer is not attached.) They don't need to be sociable, once a complete set is created.
Thanks for sharing.
Regards, Tim Chen
calls a
authoring
tool.
readable
a
standard
a
programmer.
implement
references
scripts
attributed
to
as
