Unable to use gegl operation
Unable to use gegl operation Madhav yadav 08 Apr 03:18
  Unable to use gegl operation Owen 08 Apr 04:04
   Unable to use gegl operation Madhav yadav 08 Apr 04:12
    Unable to use gegl operation Owen 08 Apr 04:40
     Unable to use gegl operation Bill Skaggs 08 Apr 16:10
Madhav yadav
2011-04-08 03:18:50 UTC (about 14 years ago)
When I try to use any gegl operation eg - load on running the file i get the error -
Message: Module '/usr/local/lib/gegl-0.1/ff-load.so' load error: /usr/local/lib/gegl-0.1/ff-load.so: undefined symbol: avcodec_decode_video2
can anyone help??
Owen
2011-04-08 04:04:32 UTC (about 14 years ago)
error -
can anyone help??
just guessing, but when you ran autogen.sh to configure gegl, did you have this output.
checking for AVFORMAT... yes checking libavformat/avformat.h usability... yes checking libavformat/avformat.h presence... yes checking for libavformat/avformat.h... yes checking linux/videodev.h usability... yes checking linux/videodev.h presence... yes checking for linux/videodev.h... yes
So do you have avformat.h
Do you have videodev.h
As I said, just a guess
Owen
Madhav yadav
2011-04-08 04:12:22 UTC (about 14 years ago)
error -
can anyone help??
Owen
I searched for avformat.h and found it on my system -
/usr/include/libavformat/avformat.h
what actually is this error from??
Owen
2011-04-08 04:40:04 UTC (about 14 years ago)
i
get the
error -
can anyone help??
have this output.
Owen
Again, I am only guessing but avcodec_decode_video2 is a variable or function for decoding video.
What system are you using. just install anything that looks like avformat, libavcodec, ffmpeg, anything to do with video then recompile gegl and try again.
you are simply missing something.
Owen
Bill Skaggs
2011-04-08 16:10:34 UTC (about 14 years ago)
It is likely that the problem comes from using a version of the ffmpeg library different from what gegl expects -- possibly due to having multiple versions of the library on your system. If you don't want to spend time figuring out how to solve that, the simplest solution, I believe, is to rebuild gegl using the --without-libavformat configure option.
-- Bill
