Gimp Plugin semi-flatten ported to Gegl op.
Gimp Plugin semi-flatten ported to Gegl op. shivani maheshwari 07 Apr 11:12
shivani maheshwari
2011-04-07 11:12:02 UTC (about 14 years ago)
I am Shivani and have ported the gimp plugin 'semi-flatten' to Gegl op. This is in addition to the task( posted earlier to the list ) - giving the code review and algorithm description as mentioned in Gsoc tasks
list.
Kindly review the patch -
diff --git a/semi-flatten.c b/semi-flatten.c index e69de29..ff18455 100644
--- a/semi-flatten.c
+++ b/semi-flatten.c
@@ -0,0 +1,70 @@
+/* Semi-flatten plugin using gegl op + *
+ * Shivani Maheshwari
+#include "config.h"
+#include
+#ifdef GEGL_CHANT_PROPERTIES
+#else
+#define GEGL_CHANT_TYPE_POINT_FILTER +
+#define GEGL_CHANT_C_FILE "semi-flatten.c" +
+#include "gegl-chant.h"
+static void prepare (GeglOperation *operation) +{
+ gegl_operation_set_format (operation, "input", babl_format ("RGBA float"));
+ gegl_operation_set_format (operation, "output", babl_format ("RGBA float"));
+static gboolean
+process (GeglOperation *op,
+ void *in_buf, + void *out_buf, + glong n_pixels, + const GeglRectangle *roi)
+ GeglChantO *o = GEGL_CHANT_PROPERTIES (operation); + gfloat *GEGL_ALIGNED in_pixel;
+ gfloat *GEGL_ALIGNED out_pixel;
+ glong i;
+ in_pixel = in_buf;
+ out_pixel = out_buf;
+ for (i=0; iprepare = prepare;
+ point_filter_class->process = process; +
+ operation_class->name = "gegl:semi-flatten"; + operation_class->categories = "color"; + operation_class->description = _("Semi flattens the image"); +}
+#endif
