Standard Keyboard Shortcut for Don't Save Button
Standard Keyboard Shortcut for Don't Save Button Charlie De 09 Mar 16:55
  Standard Keyboard Shortcut for Don't Save Button Sven Neumann 09 Mar 20:42
Charlie De
2011-03-09 16:55:39 UTC (about 14 years ago)
Hello all,
I would like to make a request if I may for the keyboard shortcut, the key that corresponds to the underlined letter, for the Don't Save button in Save/Save As dialogs to be standardised, preferrably to the "d" key. At present, this is inconsistent, in some instances the key is "n".
Some time ago I successfully edited the source files for version 2.6.11 to this effect, but after compiling and installing the program a number of issues arose that weren't present when using a binary from a repository, so I don't plan on compiling again if I can avoid it. As far as I remember, it's a small change, to be made in one or two of the files containing interface strings or settings.
Here's hoping we can all agree that "d" should be the key, and some kind soul implements the change.
Thanks for all your good work and best wishes with the coding.
Charlie
2011-03-09 20:42:18 UTC (about 14 years ago)
On Wed, 2011-03-09 at 08:55 -0800, Charlie De wrote:
Hello all,
The current development version (which is where such a change would have to happen), doesn't use the string "Don't Save" any longer.
