git pull of gegl doesn't work with git pull of gimp
git pull of gegl doesn't work with git pull of gimp Patrick Horgan 03 Mar 23:25
  git pull of gegl doesn't work with git pull of gimp Michael Natterer 03 Mar 23:30
   git pull of gegl doesn't work with git pull of gimp Patrick Horgan 03 Mar 23:50
Patrick Horgan
2011-03-03 23:25:01 UTC (over 14 years ago)
I did a git pull of babl, gegl, and gimp today just to get any changes and gimp won't configure now, complaining that:
checking for GEGL... no configure: error: Package requirements (gegl >= 0.1.6) were not met:
Requested 'gegl >= 0.1.6' but version of GEGL is 0.1.5
and indeed:
pkg-config --modversion gegl 0.1.5
Is there a quick workaround I can do, i.e. change these:
Makefile:BABL_REAL_VERSION = 0.1.5 Makefile:BABL_VERSION = 0.1.5
Makefile:PACKAGE_STRING = babl 0.1.5 Makefile:PACKAGE_VERSION = 0.1.5
Makefile:VERSION = 0.1.5
and remake? Does someone need to check into the gegl trunk?
Patrick
Michael Natterer
2011-03-03 23:30:51 UTC (over 14 years ago)
checking for GEGL... no configure: error: Package requirements (gegl>= 0.1.6) were not met:
Requested 'gegl>= 0.1.6' but version of GEGL is 0.1.5
and indeed:
No. Simply never say ./configure on something you got from git. Configure is for tarballs. Use ./autogen.sh instead.
--mitch
Patrick Horgan
2011-03-03 23:50:04 UTC (over 14 years ago)
and indeed:
Well, really, I just did: git pull and then make install;) It ran a configure on it's own. I'll have to remember to run autogen.sh after the git pull. Thanks!
Patrick
--mitch
