Starting help for gimp-2.8
Starting help for gimp-2.8 Julien Hardelin 03 Mar 06:07
  Starting help for gimp-2.8 Roman Joost 05 Mar 22:46
   Starting help for gimp-2.8 Julien Hardelin 29 Mar 06:48
    Starting help for gimp-2.8 Michael Grosberg 29 Mar 11:13
Julien Hardelin
2011-03-03 06:07:00 UTC (about 14 years ago)
According to the GIMP developers wiki http://gimp-wiki.who.ee/index.php/GIMP_Roadmap, only layer groups and single-window mode will change until gimp-2.8 release (and probably only for bug fixes). We can reasonably consider that gimp-2.8 will be released within a few monthes.
More than 6 monthes were necessary to update gimp-help-2 to 2.6.
So, I think we should start writing gimp-2.8 help now.
For that, we need: - a separated git module for gimp-help-2.8, containing a copy of the present gimp-help-2 at first.
- a gimp-doc-wiki(like the old we had) with the list of features that must be updated, and the possibility of knowing who works on what.
Unfortunately, I have not the knowledge to build a git module or a gimp wiki :-(.
Greetings,
Julien
Roman Joost
2011-03-05 22:46:37 UTC (about 14 years ago)
Hi Julien,
On Thu, Mar 03, 2011 at 07:07:00AM +0100, Julien Hardelin wrote:
For that, we need:
Perhaps for this, the developers wouldn't mind if the documentation team could use the wiki as well?
I could perhaps ask on the developer mailing list for this opportunity...
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Julien Hardelin
2011-03-29 06:48:58 UTC (about 14 years ago)
Hi Roman,
For that, we need:
The wiki is not the most important as long as contributors are few. But what about a separated module for gimp-help-pre-2.8?
Michael sent a re-written quickie.xml file. This tutorial is much better than the present one, but it refers to the Export command, which is a gimp-2.7 feature.
I can't push it to the gimp-help-2 repository. Michael is a valuable recruit for gimp-help. I'm afraid he will turn discouraged if its work is not validated.
Cheers,
Julien
Michael Grosberg
2011-03-29 11:13:58 UTC (about 14 years ago)
I can rewrite that section for 2.6 - it's not much of a change - and keep this version for when, gnu willing, the new version comes out.
2011/3/29 Julien Hardelin
Hi Roman,
For that, we need:
Cheers,
Julien _______________________________________________ Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
