Scale bars in 2.7
Scale bars in 2.7 Emil Assarsson 23 Jan 23:33
  Scale bars in 2.7 Cedric Sodhi 24 Jan 16:08
Emil Assarsson
2011-01-23 23:33:36 UTC (about 14 years ago)
Scale bars in 2.7
Hi all,
I know that 2.7 is still in development and much will change but I hope you don't mind some comments.
This is about the scale bars in the brush attribute editor etc.
I find it hard to use especially when I try to set the Size to something less than 40 in the normal width. Is it possible to add some kind of decelerator (hotkey?) on those so it would be easier to fine tune? I find the small up and down buttons useless. It might be an idea to adjust the scale to reflect the zoom from 1:1 pixel? It would also be nice if the number where selected so they easily could be replaced with a new value without having to try to select it by dragging the mouse pointer which may or may not work depending on where the scale bar is located.
BR
Emil Assarsson
Cedric Sodhi
2011-01-24 16:08:43 UTC (about 14 years ago)
Scale bars in 2.7
Hi, I think this is already being adressed for 2.8. You are not the only one who is bothered by this.
Basing the rate of change upon the current zoom is a very good idea! It would definitly make sense to have the slider automatically cover a range between 1px and
On Mon, Jan 24, 2011 at 12:33:36AM +0100, Emil Assarsson wrote:
Hi all,
BR
Emil Assarsson
