Coding Convention Question
Coding Convention Question Eric Grivel 22 Jan 00:05
  Coding Convention Question Sven Neumann 22 Jan 14:01
Eric Grivel
2011-01-22 00:05:25 UTC (over 14 years ago)
I'm looking at bug #596410 and in order to get to the import source in gimpimage.c, I seem to have to #include "../file/gimp-file.h" (to get to the GIMP_FILE_IMPORT_SOURCE_KEY constant). Is it appropriate to include a header file from a sibling directory this way?
Thanks, Eric
2011-01-22 14:01:17 UTC (about 14 years ago)
No, you just #include "file/gimp-file.h". The include paths for the compiler are configured so that this will work.
