tags missed in preferences
tags missed in preferences Ignacio 04 Jan 14:07
  tags missed in preferences "Kolbj 04 Jan 15:27
   tags missed in preferences Ignacio 04 Jan 16:59
Ignacio
2011-01-04 14:07:51 UTC (over 14 years ago)
Hi
The tags ( ) for GIMP are missing
in some xml files (src/using/preferences/). Ignacio
"Kolbj
2011-01-04 15:27:28 UTC (over 14 years ago)
Den 04.01.2011 15:07, skreiv Ignacio:
Hi
I think you, or some other, may add the missing tags (in the src/*.xml files) next time you are committing something. As far as I can see, the only thing the tag does is to capitalize the contents. (Outputs GIMP when someone writes gimp). Kolbjoern
Ignacio
2011-01-04 16:59:59 UTC (over 14 years ago)
2011/1/4 Kolbjørn Stuestøl
Hi
Yes the GIMP Doc work without that tag, I can see it,too Sorry, but I'm not a committer. And I'm translating po files. Thanks
Ignacio
