Suggestion for upcoming transformation tool
Suggestion for upcoming transformation tool Ofnuts 13 Nov 13:27
2010-11-13 13:27:33 UTC (over 14 years ago)
Just read the specs here:
http://gui.gimp.org/index.php/Transformation_tool_specification
I like that very much... except this:
Transformation constraints
from centre
works on scale and shear, toggled by [...]
centre/corner rotate
works on rotation axis, toggled by
Constraining the scale around the center is arbitrary. Scale could be constrained around any fixed point, and this fixed point could as well be the already defined rotation axis (which, by default, is at the center...). If I want to adjust a layer over another one, I don't want scale to move things around. I would move the upper layer until one of its pixels is at its final place, then pin that one down and rotate/scale the upper layer to make at least another pixel match.
Additional suggestion; the current crosshair design masks the reference pixel, and in many cases the lines leading to it. A diagonal crosshair with a 3x3 pixels clear center could be better.
-- ofnuts
