2.7: selection to path procedure lookup failed.
2.7: selection to path procedure lookup failed. Ofnuts 08 Nov 22:22
  2.7: selection to path procedure lookup failed. Martin Nordholts 09 Nov 06:17
   2.7: selection to path procedure lookup failed. Ofnuts 09 Nov 08:09
    2.7: selection to path procedure lookup failed. Martin Nordholts 09 Nov 19:24
     2.7: selection to path procedure lookup failed. Ofnuts 10 Nov 01:07
2010-11-08 22:22:16 UTC (over 14 years ago)
I'm trying to have coexisting a locally built 2.7 and a packaged 2.6.8.
2.6.8 goes to /usr/bin and /usr/lib and 2.7 installs into /usr/local/lib and /usr/local/bin
I start 2.7 via a shell that export LD_IBRARY_PATH and updates the PATH so tha the /usr/local stuff goes first.
2.7 seems to work (all tools I tried worked, especially the 2.7-specific cage tool) except when I try to transform a selection to path, for which I get:
"Selection to path procedure lookup failed."
If I recall correctly, my freshly built, bytes-still-wet, 2.7 did work correctly, so I must have broken something when playing with the system load paths. Can anyone suggest where to look?
Martin Nordholts
2010-11-09 06:17:25 UTC (over 14 years ago)
Just a couple of tips:
* Don't install into a prefix in a prefix, rather use /usr and /opt * You shouldn't need to set LD_IBRARY_PATH when you run (only when you ./configure) because built binaries will have library paths hardcoded in them through rpath [1], unless you disabled that.
/ Martin
[1] http://en.wikipedia.org/wiki/Rpath_(linking)
2010-11-09 08:09:49 UTC (over 14 years ago)
Ain't me... I used all defaults in the Git build scripts.
OK, will look that up.
Thanks.
Martin Nordholts
2010-11-09 19:24:46 UTC (over 14 years ago)
Well, the default prefix is for when you want to override an installation in /usr, if you don't want that, which is the case here, it is your responsibility to change it to something else. Pass --prefix=/opt to autogen.sh or configure.
/ Martin
2010-11-10 01:07:36 UTC (over 14 years ago)
Worked a treat. Now both versions seem to coexist peacefully. Thanks.
/ Martin
