Layer-Visibility in rotate tool: always 100%
Layer-Visibility in rotate tool: always 100% oliver@first.in-berlin.de 17 Aug 21:37
  Layer-Visibility in rotate tool: always 100% oliver@first.in-berlin.de 17 Aug 23:45
  Layer-Visibility in rotate tool: always 100% Gino D 18 Aug 00:04
  Layer-Visibility in rotate tool: always 100% GSR - FR 18 Aug 01:05
2010-08-17 21:37:34 UTC (over 14 years ago)
in the rotate tool, when I make the visibility < 100% this simply does not work.
The layer that will be rotated is always 100% visibile.
Will it be enough to mention it here (because of a possible quick fix)? Or should I file a bug-report (or maybe there already is one for that problem?)?
It's Gimp 2.6.7.
Ciao, Oliver
2010-08-17 23:45:02 UTC (over 14 years ago)
...this is only in backward (correcting) mode.
Maybe it's intended behaviour... ?!
It's Gimp 2.6.7.
Ciao, Oliver
Gino D
2010-08-18 00:04:49 UTC (over 14 years ago)
2010/8/17 :
The layer that will be rotated is always 100% visibile. Will it be enough to mention it here (because of a possible quick fix)? Or should I file a bug-report (or maybe there already is one for that problem?)?
It's Gimp 2.6.7.
Ciao,
 Oliver
There is to add that, besides the opacity, also the layer mode is not correctly previewed during the handling of the Rotate Tool, since the rotating layer is always shown as if its mode would be temporarily set to "Normal" even when it doesn't.
Moreover, this flaw seems to affect other Transform Tools as well, like Scale, Shear and Perspective.
GSR - FR
2010-08-18 01:05:43 UTC (over 14 years ago)
oliver@first.in-berlin.de (2010-08-17 at 2137.34 +0200):
Always search first.
https://bugzilla.gnome.org/show_bug.cgi?id=520460
GSR
