Q: cygwin GIMP build problems: missing execinfo.h
Q: cygwin GIMP build problems: missing execinfo.h Jim C 30 Jun 16:39
  Q: cygwin GIMP build problems: missing execinfo.h Tor Lillqvist 30 Jun 16:53
Jim C
2010-06-30 16:39:43 UTC (almost 15 years ago)
Greetings,
Can anyone tell me the trick to building GIMP under cygwin (on Windows XP 64-bit).
My immediate problem is that the GEGL make fails because execinfo.h is not found.
The doc page at http://www.gnu.org/software/gnulib/manual/html_node/execinfo_002eh.html says "This header file is missing on all non-glibc platforms: ... Cygwin, mingw".
The description of bug 613537 (https://bugzilla.gnome.org/show_bug.cgi?id=613537) suggests that the build should not be including this file on windows platforms.
Possibly the GEGL autoconf script is confused by 64-bit Windows?
Thanks in advance.
Tor Lillqvist
2010-06-30 16:53:09 UTC (almost 15 years ago)
You really mean you are building for Cygwin, not Windows?
Well, most likely nobody has attempted to build GEGL for Cygwin before.
Well, Cygwin is a Unix platform. It should not be treated as Windows. It's just a coincidence that Cygwin runs on top of Windows.
--tml
