<Palettes> should be translated ?
<Palettes> should be translated ? Cristian Secar? 31 May 09:16
  <Palettes> should be translated ? LightningIsMyName 31 May 12:41
   <Palettes> should be translated ? Sven Neumann 31 May 21:06
Cristian Secar?
2010-05-31 09:16:22 UTC (almost 15 years ago)
This string should be fully translated, or is some code variable ?
#: ../plug-ins/script-fu/scripts/palette-export.scm.h:1 msgid "/Export as"
Cristi
LightningIsMyName
2010-05-31 12:41:29 UTC (almost 15 years ago)
Hello Cristi,
2010/5/31 Cristian Secar?
I wrote that script, and the "" part should not be translated. "" means that this script will be located in the menu of the palette dialog.
The rest of the string (the "Export As") should be translated, as this is the actual menu name of the script.
Thanks for translating my script =) LightningIsMyName
2010-05-31 21:06:01 UTC (almost 15 years ago)
On Mon, 2010-05-31 at 13:41 +0300, LightningIsMyName wrote:
Hello Cristi,
We should really have reviewed this script better before adding it to the distribution. It is of course wrong to mark the menu paths translatable. These string should not be translated at all. I'll fix this asap.
