hotspot means the same as hot spot ?
hotspot means the same as hot spot ? Cristian Secar? 21 May 09:42
  hotspot means the same as hot spot ? Sven Neumann 21 May 22:20
Cristian Secar?
2010-05-21 09:42:23 UTC (almost 15 years ago)
In the plug-ins .po file there are a number of new strings containing „hotspot”. However, in the same file, some older strings contain „hot spot”.
Both expressions refer to the same thing ?
Cristi
2010-05-21 22:20:31 UTC (almost 15 years ago)
Yes, they do. I have pushed a change to master that makes the strings consistent with what is used in the XBM plug-in.
