cannot start 2.7 from git
cannot start 2.7 from git Alexander Rabtchevich 02 Apr 13:45
  cannot start 2.7 from git Jon Nordby 02 Apr 16:45
  cannot start 2.7 from git Liam R E Quin 02 Apr 17:32
   cannot start 2.7 from git Alexander Rabtchevich 02 Apr 17:45
    cannot start 2.7 from git Bill Skaggs 03 Apr 03:25
2010-04-02 13:45:17 UTC (about 15 years ago)
Hello
I compiled current git under Ubuntu 9.10 against babl 0.1.2 and gegl 0.1.2 without gtk-docs. When I try to run gimp only writes in the console
... gimp-2.7:687: warning [p 29, 2.0i]: cannot adjust line gimp-2.7:687: warning [p 29, 2.2i]: cannot adjust line gimp-2.7:687: warning [p 29, 2.3i]: cannot adjust line gimp-2.7:687: warning [p 29, 2.5i]: cannot adjust line gimp-2.7:687: warning [p 29, 2.7i]: cannot adjust line gimp-2.7:687: warning [p 29, 2.8i]: cannot adjust line gimp-2.7:687: warning [p 29, 3.0i]: cannot adjust line gimp-2.7:687: warning [p 29, 3.2i]: cannot adjust line gimp-2.7:687: warning [p 29, 3.5i]: cannot adjust line ...
Is there a solution?
With respect, Alexander Rabtchevich
Jon Nordby
2010-04-02 16:45:00 UTC (about 15 years ago)
On Fri, Apr 2, 2010 at 1:49 PM, Alexander Rabtchevich < alexander.v.rabtchevich@iaph.bas-net.by> wrote:
Hello
---- console output ----
Make sure that you don't have a Gimp (2.6) instance running. If you do, it will connect to it and just pop up a new image window there when you run "gimp-2.7". If that is not the issue, please pastebin the entire console output (and the command you are running).
Liam R E Quin
2010-04-02 17:32:40 UTC (about 15 years ago)
On Fri, 2010-04-02 at 14:49 +0300, Alexander Rabtchevich wrote:
Hello
I don't know about that error, but I recently found I need to remove a file called "context" from my ~/.gimp-git directory, as otherwise gimp dumped core on startup.
So try that, and if that doesn't help, rename your gimp directory and see if it then starts.
My gimp doesn't contain "cannot adjust line" so maybe it's coming from a plugin or from a library - e.g. libgtk-x11
Liam
2010-04-02 17:45:40 UTC (about 15 years ago)
Hello
Liam
It's strange, but when I closed terminal and ran GIMP from Nautilus, it started OK. Do not know, what was wrong.
Bill Skaggs
2010-04-03 03:25:16 UTC (about 15 years ago)
That error message comes from groff, a text-formatting program. But I don't know why gimp would be invoking groff. The most common time it is invoked is in printing man pages, but that doesn't seem likely to apply here.
-- Bill
