gegl-0.1.2
gegl-0.1.2 Øyvind Kolås 07 Feb 17:04
  gegl-0.1.2 bgw 07 Feb 18:01
Øyvind Kolås
2010-02-07 17:04:15 UTC (about 15 years ago)
gegl-0.1.2
GEGL 0.1.2
GEGL (Generic Graphics Library) is a graph based image processing framework.
GEGL provides a graph based API and framework to do demand driven, cached, non destructive image editing of larger than RAM images. Through babl it provides support for a wide range of color models and pixel storage formats for input and output.
To build gegl-0.1.2 you will also need babl-0.1.2
Changes in this release ???????????????????????
• GeglLookup, configurable floating point lookup tables for lazy computation. • Use GFileIOStream in GeglTileBackendFile. • Optimizations: in-place processing for point filters/composers, SIMD version of gegl:opacity, avoid making unneccesary sub-buffers, removed some manual instrumentation from critical paths, improved speed of samplers. In some cases with current GIMP this leads to a doubling of the performance.
• Added xml composition/reference image based regression tests. • Added performance tracking framework. • Syntactic sugar using varargs for constructing gegl graphs from C. • Build fixes on cygwin,
• Gegl# fixes.
• Initial, but unstable code towards multithreading. • Improvements to lua op in workshop. • Added new resamplers upsize, upsharp, upsmooth, downsize, downsharp and downsmooth.
• Removed gegl:tonemap and gegl:normal ops.
This release of GEGL brought was brought to you by: Martin Nordholts, Sven Neumann, Nils Philippsen, Adam Turcotte, Danny Robson, Michael Schumacher, Ruben Vermeersch, Øyvind Kolås, Javier Jardón, Yaakov Selkowitz and Michael Natterer, Kaja Liiv and Eric Daoust.
Where to get GEGL ?????????????????
The latest versions of GEGL and it's hard dependencies babl and glib can be fetched from:
ftp://ftp.gimp.org/pub/babl/0.1/babl-0.1.2.tar.bz2 ftp://ftp.gimp.org/pub/gegl/0.1/gegl-0.1.2.tar.bz2 ftp://ftp.gtk.org/pub/glib/2.20/glib-2.20.5.tar.bz2
The integrity of the tarballs can be verified with:
sha1sum *.bz2 1abe98b11e67737b6f74d6993d45046eec93bcda babl-0.1.0.tar.bz2 34b4a6be9e472324d6dd1233713a1f8851fcdc04 gegl-0.1.2.tar.bz2 19e2b2684d7bc35a73ff94eb7fd15fc70cc6f292 glib-2.20.5.tar.bz2
Where to get more information about GEGL ???????????????????????????????????????? More information about GEGL can be found at the GEGL website
bgw
2010-02-07 18:01:46 UTC (about 15 years ago)
gegl-0.1.2
should be babl-0.1.2.tar.bz2 - sha1 sum is correct, tho
don't you just hate it when people get picky about these little typos?
