Patch for rectangle func and GeglRectangle initialization in tests/buffer/buffer-test.c
Patch for rectangle func and GeglRectangle initialization in tests/buffer/buffer-test.c Albert Chin 29 Nov 17:31
Albert Chin
2009-11-29 17:31:05 UTC (over 15 years ago)
1. The void rectangle function in tests/buffer/buffer-test.c should be static void to match the prototype. 2. You cannot initialize rect when you declare it in rectangle() unless you assume a C99 compiler.
Patch for both issues attached.
