test_start() uses G_STRFUNC to determine function name
test_start() uses G_STRFUNC to determine function name Albert Chin 29 Nov 17:17
  test_start() uses G_STRFUNC to determine function name Martin Nordholts 01 Dec 20:01
Albert Chin
2009-11-29 17:17:55 UTC (over 15 years ago)
tests/buffer/buffer-test.c uses G_STRFUNC to print the name of the test function. However, this assumes the compiler supports __PRETTY_FUNCTION__ or __func__. If it doesn't, then test output is prepended with:
Test: ???
This basically causes the diff comparison to fail for most non-GCC compilers. Patch attached to fix this by manually adding the function name. Yeah, ugly, but I can't see an easier way to fix this.
Martin Nordholts
2009-12-01 20:01:43 UTC (over 15 years ago)
Test: ???
It seems like a reasonable workaround to an ugly problem to me. Could you provide your patches (the other two as well) in git format-patch format?
BR, Martin
