animation-play
animation-play Mircea Purdea 16 Nov 16:50
  animation-play Martin Nordholts 16 Nov 21:43
   animation-play Martin Nordholts 16 Nov 22:41
Mircea Purdea
2009-11-16 16:50:48 UTC (over 15 years ago)
animation-play
Hello everyone,
I'm new to the list (and to GIMP development) so you'll have to excuse my general noob-ness. I've been using the GIMP for a few years now, and one of the features I often use is the Animation-Playback plugin. Now, I know about GAP (and I use that, too) but the Playback function is still a staple of GIMP use for me. And with that in mind, I thought that this part of GIMP could really use some love; the TO-DO comments have been there for, what, 10 years now?
Now me, I'm very much a beginner when it comes to C, GTK+ and GIMP internals, so I can't really do all that much at this point. What I found I can do (for myself, even if not for inclusion in the stable tree) is
add a UI element for default frame duration. This is something which for me is very important: I work mostly at 12 FPS, so the implicit 100ms is not good enough for me. To this end, I added another combo box to the animation-playback window, with a set of predefined (standard) framerates. I also changed the listing in the duration adjuster combo from % values to 'x'. To me this seems more intuitive (as I think that many people who see the original % values will initially think that the adjuster is used for zoom, rather than speed).
Here is a screenshot to see what I mean: http://nothing.exhalus.net/misc/animation-play.gif
Source code can be downloaded from: http://nothing.exhalus.net/misc/animation-play.zip
The source file is modified from the 2.7 version in git. Now, being a noob, I have yet to find a way to compile this as a stand-alone plugin. If I use the gimptool, I get "initializer element is not constant" errors in 'ui_manager_new'. The only way I could compile this was by doing a full GIMP build from the git source. And while this works in Linux, I can't use this method on Windows. I was able to compile other plugins on Windows, but I never managed to sort out all dependencies for a full Win32 GIMP build. Could anyone help with this?
Also, what do you guys think (in code and design terms) about these UI additions/changes?
Mircea
Martin Nordholts
2009-11-16 21:43:15 UTC (over 15 years ago)
animation-play
Hi Mircea!
Modifications to software is generally distributed as patches, look at [1] for basic instructions on how to generate a patch with git.
Yes, the "plug-in" has dependencies to private API, most of it for internationalization. Should be easy to convert it to a proper plug-in.
I haven't looked at the, but the UI changes seems sane to me.
Regards, Martin
Martin Nordholts
2009-11-16 22:41:06 UTC (over 15 years ago)
animation-play
I forgot to add:
[1] http://gimp.org/bugs/howtos/submit-patch.html
/ Martin
