gegl's make doesn't find babl
gegl's make doesn't find babl Florent Monnier 05 Aug 13:06
gegl's make doesn't find babl Martin Nordholts 07 Aug 18:18
gegl's make doesn't find babl Florent Monnier 07 Aug 18:43
Florent Monnier
2006-08-05 13:06:45 UTC (over 18 years ago)
I'm following the steps described in the shell script: http://pippin.gimp.org/gegl/index.html#bootstrapping
everythings work just fine until the make for gegl, it ends with:
checking for BABL... configure: error: Package requirements (babl >= 0.0) were
not met.
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively you may set the BABL_CFLAGS and BABL_LIBS environment variables
to avoid the need to call pkg-config.  See the pkg-config man page for
more details.
Configure failed or did not finish!
__________________________________________
I don't know what I should set in PKG_CONFIG_PATH ?
thanks
Martin Nordholts
2006-08-07 18:18:52 UTC (over 18 years ago)
__________________________________________ checking for BABL... configure: error: Package requirements (babl >= 0.0) were
not met.
Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix.
to avoid the need to call pkg-config. See the pkg-config man page for more details.
Configure failed or did not finish! __________________________________________
thanks
I got that too, and got rid of it by checking out babl from CVS and doing the usual ./autogen.sh + make + sudo make install
__________________
Florent Monnier
2006-08-07 18:43:02 UTC (over 18 years ago)
not met.
thanks
babl is installed
I've followed each steps of pippin's script scrupulously but this problem is there
or do you mean that the content of the cvs has haved since my post and that i should re-check-out it now ?
