Force gimp reload plugins?
Force gimp reload plugins? Louise Hoffman 25 Oct 03:53
  Force gimp reload plugins? David Hodson 25 Oct 04:06
   Force gimp reload plugins? Sven Neumann 25 Oct 17:30
    Force gimp reload plugins? Louise Hoffman 25 Oct 23:32
Louise Hoffman
2009-10-25 03:53:52 UTC (almost 16 years ago)
Dear developers
Is there a quick way to test (my) plugin when I just have compiled it?
What I do right now is: * compile
* su
* make install
* quit gimp
* start gimp
and it takes forever.
Is there a quicker way? E.g. a way to force gimp to reload the plugins? =)
Hugs, Louise
David Hodson
2009-10-25 04:06:22 UTC (almost 16 years ago)
Once Gimp has been started with the plugin present, you can just replace the executable (make install) and call up the plugin again - Gimp will run the new version. You only need to restart Gimp the first time that you add a new plugin. (As long as the name of the executable and the name of the plugin don't change.)
-- David
2009-10-25 17:30:12 UTC (almost 16 years ago)
To be more exact, you don't have to restart GIMP as long as changed plug-in still registers the same procedure and installs the same menu(s).
Louise Hoffman
2009-10-25 23:32:23 UTC (almost 16 years ago)
[snip]
Dear David and Sven
Thanks so much. That will speed up the development a lot =)
Hugs, Louise
