Hide progress bar
Hide progress bar Cristi Balas 06 Oct 16:08
  Hide progress bar Aurimas Juška 06 Oct 20:30
  Hide progress bar Sven Neumann 06 Oct 20:31
Cristi Balas
2009-10-06 16:08:28 UTC (about 16 years ago)
Hide progress bar
Hi!
I have a perl plugin that calls gimp-file-load-layer. and when i call this function, a progress bar apears in the status bar (if the status bar is hidden, then it's temporary made visible). I want my plugin not to display any progress bar / status bar.
Is gimp-progress-install function going to help me? if so, how do i use it?
I looked everywhere for this function, but can't find a usage scenario to test it if it's gonna help me.
Thanks
Aurimas Juška
2009-10-06 20:30:56 UTC (about 16 years ago)
Hide progress bar
You can simply create a hidden GimpProgressBar, which will handle all the difficulties of gimp-progress-install for you. All progress / status info will go to the created GimpProgressBar, but user will not see it.
2009-10-06 20:31:27 UTC (about 16 years ago)
Hide progress bar
On Tue, 2009-10-06 at 17:08 +0300, Cristi Balas wrote:
Hi!
You can use gimp_progress_install() to take over responsibility of the progress handling. Then your plug-in can just do nothing from the installed callbacks and the result will be no progress bar.
