FW: GIMP, GEGL and raw image formats
FW: GIMP, GEGL and raw image formats us3r07@web.de 13 Sep 11:49
  FW: GIMP, GEGL and raw image formats Monty Montgomery 13 Sep 21:16
us3r07@web.de
2009-09-13 11:49:56 UTC (over 15 years ago)
Thanks for the quick response Martin! Sounds great!
Years ago I made a feature request on the bug tracker and asked for adding support for raw images, but finally it ended in a resolved - wontfix. But that was afaik a while before there were any intentions to switch to GEGL. And if GEGL provides this ability by default, why not using it in GIMP? :)
For the time being I have to use UFRaw for that job.
Regards, Micha
Hi!
GIMP's product vision [1] is among other things to be a high-end photo manipulation application. That includes the ability to import and edit RAW images. So yes, some day that will be possible to do in GIMP.
Martin
_________________
Monty Montgomery
2009-09-13 21:16:44 UTC (over 15 years ago)
I believe that is exactly what's planned. It's alot of work and so will take time.
It's also the case that GEGL is not as complete as Gimp, at least not yet. It makes no sense to adopt GEGL if it means eliminating most of the Gimp's existing features to do so. GEGL itself must be finished first.
Monty
