xml2po and makefile
xml2po and makefile Vitaly Lomov 04 Sep 12:10
  xml2po and makefile Ulf-D. Ehlert 05 Sep 14:43
Vitaly Lomov
2009-09-04 12:10:42 UTC (over 15 years ago)
xml2po and makefile
after running autogen the makefile does not contain a value for XML2PO variable and I have to manually point it to tools/xml2po. Is it intended? I know we use our own xml2po with the patch, but can the toolchain be updated for this? I use cygwin on windows. Vitaly
Ulf-D. Ehlert
2009-09-05 14:43:21 UTC (over 15 years ago)
xml2po and makefile
Vitaly Lomov (Freitag, 4. September 2009, 12:10):
autogen.sh (more exactly: configure) uses your PATH environment variable to find an xml2po binary. If xml2po is not found, XML2PO is empty.
You can specify XML2PO when calling autogen.sh: ./autogen.sh ... XML2PO=/abs/path/to/.../tools/xml2po
Ulf
