transparent border when scaling etc
transparent border when scaling etc Eric Daoust 17 Jul 03:26
Eric Daoust
2009-07-17 03:26:59 UTC (over 16 years ago)
This concerns the "added transparent border" bug (feature?):
http://bugzilla.gnome.org/show_bug.cgi?id=549999
From my observations, it seems the border removal may have to be done
through image crop after the completion of the image. I will refer to the gegl/operations/affine.c file's method get_bounding_box. Our goal was to hopefully feed both the larger bounding box AND the smaller box that terminates at the borders of the image itself. Unfortunately, the larger bounding box is actually not directly fed to anything; it is instead returned to the caller. This method is an inheritance of a parent class (99% sure) so changing the return type could be a real pain in the neck.
The code which "adds the border" is this:
in_rect.x += context_rect.x; in_rect.y += context_rect.y;
in_rect.width += context_rect.width; in_rect.height += context_rect.height;
Nicolas' idea was that a second bounding box would be "carried around," one which has not been enlarged to accomodate the footprint of the sampler as above.
Comments?
Eric
