Integrating GEGL into MLT video engine -> Kdenlive
Integrating GEGL into MLT video engine -> Kdenlive Jean-Michel Pouré 08 Jul 00:52
  Integrating GEGL into MLT video engine -> Kdenlive Martin Nordholts 08 Jul 07:15
   Integrating GEGL into MLT video engine -> Kdenlive Jean-Michel Pouré 08 Jul 08:35
    Integrating GEGL into MLT video engine -> Kdenlive Martin Nordholts 08 Jul 18:45
Jean-Michel Pouré
2009-07-08 00:52:19 UTC (over 16 years ago)
Dear all,
We are interested to use GEGL to add effects to MLT video engine (http://www.mltframework.org). MLT provides the core features to read and write video. We need powerful image processing features.
MLT is available here: git clone git://mltframework.org/mlt.git
For a working example, install Kdenlive video editor: http://www.kdenlive
An example of integration is provided with Frei0r-plugin effects. It is in the modules/frei0r directory.
Today, I read this article about Kdenlive: http://www.kdenlive.org/forum/kdenlive-v075-review-eugenia-osnewscom
We would like to address colour grading issues. Also we need a reliable solution. We thought of Gimp and then discovered your library.
Reading Frei0r code, do you think GEGL could be easily integrated into MLT? Do you think GEGL is suited for fast image processing?
Would someone here be interested in helping us?
Kind regards, Jean-Michel Pouré
Martin Nordholts
2009-07-08 07:15:17 UTC (over 16 years ago)
On 07/08/2009 12:52 AM, Jean-Michel Pouré wrote:
Dear all,
I didn't find the Frei0r code, could you provide a direct link please?
Yes, I think MLT will benefit from using GEGL. Currently, GEGL is not known to be particularly fast, but performance issues are going to be addressed. GIMP can't use GEGL unless it's fast, and we're determined to use GEGL in GIMP. There currently is an ongoing Google Summer of Code project looking into performance for GEGL for example.
Best regards, Martin
Jean-Michel Pouré
2009-07-08 08:35:30 UTC (over 16 years ago)
Simply: git clone git://mltframework.org/mlt.git Look into: src/modules/frei0r
for an example of integration of frei0r third-party library.
If you are running Debian, apt-get build-dep mlt to install the required compilation dependencies.
Under other platforms, it may be more difficult as there are many dependencies. But we explain how to install them here:
http://www.kdenlive.org/user-manual/downloading-and-installing-kdenlive/installing-source
Perfect. Ih hope that the changes required in MLT are minimal, like for Frei0r (a few lines). If this is the case, we can integrate GEGL quickly. We discussed today on the mailing list and we would be delighted to see GEGL in MTL. Can you help us?
Just for information, we may need to make GEGL keyframable, but I don't know the work involved.
Bye and many thanks, Jean-Michel
Martin Nordholts
2009-07-08 18:45:26 UTC (over 16 years ago)
Sure just ask whatever questions you have on this list.
There isn't an awful lot of infrastructure in place for temporal image processing, and tbh I don't know how hard it will be to add. The existing temporal-related stuff I found was:
examples/hello-world-video.c operations/external/ff-load|save.c
BR, Martin
