how to create a window in gimp plugin?
how to create a window in gimp plugin? gbstack 02 Jul 08:01
  how to create a window in gimp plugin? Adam Turcotte 02 Jul 17:52
  how to create a window in gimp plugin? Martin Nordholts 02 Jul 19:56
  how to create a window in gimp plugin? Sven Neumann 02 Jul 22:01
   how to create a window in gimp plugin? gbstack 03 Jul 07:16
gbstack
2009-07-02 08:01:16 UTC (almost 16 years ago)
Hello,everybody!
I want to create a window in gimp plugin,so this is my code(part of the plugin):
/static void run (const gchar *name, gint nparams,
const GimpParam *param,
gint *nreturn_vals, GimpParam **return_vals)
static GimpParam values[1];
GimpPDBStatusType status = GIMP_PDB_SUCCESS; GimpRunMode run_mode;
GtkWidget *window;
gtk_init();
/* Setting mandatory output values */ *nreturn_vals = 1;
*return_vals = values;
values[0].type = GIMP_PDB_STATUS; values[0].data.d_status = status;
/* Getting run_mode - we won't display a dialog if * we are in NONINTERACTIVE mode */ run_mode = param[0].data.d_int32;
window = gtk_window_new(GTK_WINDOW_TOPLEVEL); gtk_window_set_title(GTK_WINDOW(window),"hello"); gtk_widget_show(window);
gtk_main();
/but when I ran the plugin in gimp,it didn't work... and this is the error message:
(hello:12429): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(hello:12429): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
(hello:12429): LibGimp-CRITICAL **: gimp_window_set_transient: assertion `gimp_ui_initialized' failed
(hello:12429): Gtk-WARNING **: Screen for GtkWindow not set; you must always set
a screen for a GtkWindow before using the window
(hello:12429): Gdk-CRITICAL **: gdk_screen_get_default_colormap: assertion `GDK_IS_SCREEN (screen)' failed
(hello:12429): Gdk-CRITICAL **: gdk_colormap_get_visual: assertion `GDK_IS_COLORMAP (colormap)' failed
(hello:12429): Gdk-CRITICAL **: gdk_screen_get_root_window: assertion `GDK_IS_SCREEN (screen)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_new: assertion `GDK_IS_WINDOW (parent)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_enable_synchronized_configure: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_user_data: assertion `window != NULL' failed
(hello:12429): Gtk-CRITICAL **: gtk_style_attach: assertion `window != NULL' failed
(hello:12429): Gtk-CRITICAL **: gtk_style_set_background: assertion `GTK_IS_STYLE (style)' failed
(hello:12429): Gtk-CRITICAL **: gtk_paint_flat_box: assertion `GTK_IS_STYLE (style)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_accept_focus: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_focus_on_map: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_modal_hint: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gtk-CRITICAL **: gtk_window_realize_icon: assertion `widget->window != NULL' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_geometry_hints: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_unmaximize: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_unstick: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_deiconify: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_unfullscreen: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_keep_above: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_set_keep_below: assertion `GDK_IS_WINDOW (window)' failed
(hello:12429): Gdk-CRITICAL **: gdk_window_show: assertion `GDK_IS_WINDOW (window)' failed
anyone can tell me how to fix it?
any suggestion is appreciated.
Regards, Todong Ma.
Adam Turcotte
2009-07-02 17:52:28 UTC (almost 16 years ago)
I'm not sure if this helps, but when I've created gimp plugins, I've always used gimp_dialog_new () instead of gtk_window_new ().
For an example, take a look at the scale_dialog () method here: http://gsoc.rivetsforbreakfast.com/gimp/IBFNBQH.c
Adam Turcotte
Martin Nordholts
2009-07-02 19:56:19 UTC (almost 16 years ago)
On 07/02/2009 08:01 AM, gbstack wrote:
Hello,everybody!
One way that always works is looking at how other plug-ins does it, for example:
http://git.gnome.org/cgit/gimp/tree/plug-ins/common/decompose.c
Look in/around decompose_dialog()
/ Martin
2009-07-02 22:01:23 UTC (almost 16 years ago)
On Thu, 2009-07-02 at 14:01 +0800, gbstack wrote:
Hello,everybody!
Please have a look at
http://developer.gimp.org/writing-a-plug-in/1/index.html
In particular part III of this tutorial should be helpful.
gbstack
2009-07-03 07:16:00 UTC (almost 16 years ago)
thanks for your tutorials,plugin examples and suggestions.
now it's fixed,if I use gimp_ui_init instead of gtk_init,I can create a GtkWindow in gimp plugin now.
thank you all! :-)
Regards, Todong Ma
