Submitting GIT patch
7 of 7 messages available
Submitting GIT patch Eric Daoust 29 Jun 17:10
  Submitting GIT patch Martin Nordholts 29 Jun 21:53
   Submitting GIT patch Adam Turcotte 30 Jun 21:10
    Submitting GIT patch Martin Nordholts 30 Jun 21:14
    Submitting GIT patch Sven Neumann 30 Jun 23:01
   Submitting GIT patch Eric Daoust 03 Jul 19:28
    Submitting GIT patch Sven Neumann 03 Jul 20:42
Eric Daoust
2009-06-29 17:10:41 UTC (almost 16 years ago)
I'm no expert in GIT but in my experience with SVN things can become a mess if we're not careful, so I want to make sure I am doing things correctly.
I am ready to submit a working nohalo1 patch for GEGL that is a faster replacement for sharp. I believe this is the procedure I must follow. (I will backup my files just in case)
-create local branch so that I am not committing to the main trunk -remove sharp from the branch
-add nohalo1
-commit to the branch
-switch back to main branch, pull
-switch back to my local branch
-rebase with master
-fix conflicts
-create the patch
I found a similar procedure at this page: https://rails.lighthouseapp.com/projects/8994/sending-patches
Any help/advice is greatly appreciated.
Thank you for your time, Eric
Martin Nordholts
2009-06-29 21:53:59 UTC (almost 16 years ago)
-add nohalo1
-rebase with master
-fix conflicts
-create the patch
First of all, remeber that your git repository of GEGL is a clone, you can mess it up however badly you like without affecting everyone elses repo. When you get push access you need to be more careful though ;)
When you have cloned, create and checkout a branch to do your work on: git checkout -b gsoc2009-adaptive-resampler origin/master
Then do your changes. Make sure to commit often. In general, the more commits the better. Commits are easy to squash together but it's more work to separate a single commit into two.
You don't need to switch back to master, to rebase with origin/master, just do:
git pull --rebase
while you are on your gsoc2009-adaptive-resampler branch.
And note that in the end, it is not a matter of creating "the patch". Rather, your delivery should be a series of git commits created with git format-patch origin/master..gsoc2009-adaptive-resampler -o output-folder
You then tarball the output-folder and send it to us, preferably coordinated through #gegl on irc.gimp.org.
Hope this helps, feel free to ask further quetions if you need clarifications.
Oh and a final thing, make sure to look at gitk --all after each git operation so that you can see what is going on.
/ Martin
Adam Turcotte
2009-06-30 21:10:30 UTC (almost 16 years ago)
Amongst other things I have written, I have made two small changes to a file that are relevant to an open Bugzilla.
How would I go about creating a patch specifically for this file to post as an attachment to this thread?
Adam Turcotte
Martin Nordholts
2009-06-30 21:14:09 UTC (almost 16 years ago)
In short, create a new branch and base it on origin/master, cherry-pick the commit in question, then edit that commit (google for details on how to edit the last commit) into a commi that just changes that specific file
/ Martin
2009-06-30 23:01:21 UTC (almost 16 years ago)
Did you already commit this change to your tree? If not, do that now. You may want to create a branch for your local work, but that is not necessary. After you have committed your change(s), you create a patch (or a set of patches) by using the command 'git format-patch'. Have a look at 'git help commit' and 'git help format-patch' for the gory details or consult one of the many git tutorials.
Eric Daoust
2009-07-03 19:28:09 UTC (almost 16 years ago)
The nohalo patch is submitted on bugzilla (bug #587696) with sampler execution time summaries and three XML test files.
Eric
git pull --rebase
 / Martin
2009-07-03 20:42:37 UTC (almost 16 years ago)
Please do also announce this on the gegl-developer list. Thanks.
