Foreign sorting glossary
8 of 8 messages available
Foreign sorting glossary Kolbjørn Stuestøl 24 May 17:00
  Foreign sorting glossary julien 24 May 21:07
   Foreign sorting glossary Kolbjørn Stuestøl 24 May 22:08
    Foreign sorting glossary julien 25 May 10:48
     Foreign sorting glossary Kolbjørn Stuestøl 25 May 11:19
      Foreign sorting glossary Ulf-D. Ehlert 25 May 12:16
       Foreign sorting glossary Kolbjørn Stuestøl 25 May 23:57
        Foreign sorting glossary Ulf-D. Ehlert 26 May 18:39
Kolbjørn Stuestøl
2009-05-24 17:00:47 UTC (almost 16 years ago)
I'm working on the glossary.po at the moment. Is there any way to sort the keywords in the glossary in another order than in the source?
As for now it is annoying finding the keywords in the "wrong" order, for example the Norwegian word "kanal" under "c" as that's the place for the English "channel".
If not, perhaps marking the keywords with a special tag and write a program that does the job when making the xml files? Kolbjoern
julien
2009-05-24 21:07:27 UTC (almost 16 years ago)
Hi Kolbjoern,
I don't see the problem.
In french, I have, for instance, in glossary.po, "Plugins" translated to "Greffons". In the glossary html file I get 'Greffons' at the right place, between GNU and Guides...
Julien
Kolbjørn Stuestøl
2009-05-24 22:08:01 UTC (almost 16 years ago)
julien skreiv:
Hi Kolbjoern,
Julien
Well, not for me.
Norwegian: "Antialiasing" becomes "Kantutjamning". In the glossary html file I get (for "no"): "Alfakanal" (alpha channel); "Kantutjamning"; Beziérkurve (Beziér curves) ... Perhaps something to do with the problem I have with not getting the "Norwegian" images?
Have not tried making html for other languages than Norwegian. Perhaps I should?
Kolbjoern
julien
2009-05-25 10:48:31 UTC (almost 16 years ago)
I built html-no: "Kantutjamning" is between "Kanalmaskene" and "Laga", "Mjuke Kantar".
But there are a lot of problems in this file, due to the xml to po migration. Probably your problem will be resolved when these problems are fixed.
Yes, you can can build html for fr for example to see whether "greffon" is at the right place on your system.
Julien
Hi Kolbjoern,
Julien
Well, not for me.
Kolbjoern
Kolbjørn Stuestøl
2009-05-25 11:19:49 UTC (almost 16 years ago)
Hi Julien and the list
So, it works on your system. This should mean that there is something wrong with my Cygwin or my computer. As told before, I'm not able to built html files with references to the "no" images. Perhaps two pieces of the same cake? Still a lot to do ;-)
Yes, the po files are not updated since the days of xml, January/February or so. I have rewritten the glossary.po to correct the errors. But alas there is no sorting at all.
I'll be a little busy with other works the rest of today, but think I'll be able to give it a try tomorrow.
Thank you, Julien
mvh
Kolbjørn
Julien
Hi Kolbjoern,
Julien
Well, not for me.
Kolbjoern
Ulf-D. Ehlert
2009-05-25 12:16:57 UTC (almost 16 years ago)
Kolbjørn Stuestøl (Montag, 25. Mai 2009, 11:19):
I've added the "glossary.sort" parameter to stylesheets/plainhtml.xsl.in a few weeks ago, and it works fine for me (German) too.
It may be, however, that this is a new parameter and not yet supported by your docbook-xsl version (my version is 1.74.0). Check e.g.
/path/to/your/docbook/stylesheets/.../xhtml/glossary.xsl if there is a string "glossary.sort".
Ulf
Kolbjørn Stuestøl
2009-05-25 23:57:55 UTC (almost 16 years ago)
Ulf-D. Ehlert skreiv:
Ulf
I just *had* to try it this evening. Yes, my copy was too old, without the "glossary.sort" (but it is the newest in the Cygwin list! )
Downloaded and installed a newer copy and it works fine. All norwegian words in correct alphabetic order.
Thanks Ude :-)
(In the hurry I downloaded a "0" version (1.75.0), and obviously did something wrong when installing it as I got some error messages during the make process. But that have to wait until tomorrow. Tonight I celebrate.)
From a happy
Kolbjoern
Ulf-D. Ehlert
2009-05-26 18:39:13 UTC (almost 16 years ago)
Kolbjørn Stuestøl (Montag, 25. Mai 2009, 23:57): [...]
http://www.tldp.org/HOWTO/HOWTO-INDEX/os.html may give you a hint what you can do (e.g. search for "Linux+Win"). ;-)
Ulf
