lgm talk, part 2...
26 of 26 messages available
lgm talk, part 1... peter sikking 22 May 00:24
  lgm talk, part 2... peter sikking 19 Jun 17:37
   lgm talk, part 2... yahvuu 19 Jun 18:05
    lgm talk, part 2... peter sikking 19 Jun 18:34
     lgm talk, part 2... yahvuu 20 Jun 16:22
      lgm talk, part 2... Tobias Ellinghaus 20 Jun 17:02
       lgm talk, part 2... yahvuu 20 Jun 18:46
      lgm talk, part 2... peter sikking 21 Jun 18:46
    lgm talk, part 2... Alexandre Prokoudine 19 Jun 18:56
     lgm talk, part 2... Øyvind Kolås 19 Jun 23:16
   lgm talk, part 2... Chris Mohler 19 Jun 19:01
    lgm talk, part 2... peter sikking 19 Jun 19:41
     lgm talk, part 2... Chris Mohler 19 Jun 23:41
      lgm talk, part 2... yahvuu 20 Jun 18:27
       lgm talk, part 2... Chris Mohler 20 Jun 18:52
        lgm talk, part 2... yahvuu 20 Jun 19:07
         lgm talk, part 2... Chris Mohler 20 Jun 19:24
      lgm talk, part 2... peter sikking 21 Jun 18:22
       lgm talk, part 2... Chris Mohler 21 Jun 21:20
        lgm talk, part 2... peter sikking 22 Jun 16:21
       lgm talk, part 2... Graeme Gill 22 Jun 14:32
   lgm talk, part 2... Andrew A. Gill 20 Jun 01:25
    lgm talk, part 2... Martin Nordholts 20 Jun 10:13
     lgm talk, part 2... Daniel Hornung 20 Jun 18:40
      lgm talk, part 2... Daniel Hornung 20 Jun 18:43
      lgm talk, part 2... Hal V. Engel 20 Jun 21:42
peter sikking
2009-05-22 00:24:43 UTC (over 16 years ago)
lgm talk, part 1...
guys,
just to let you know that I have blogged the first part of my lgm talk, read all about it at:
enjoy,
--ps
peter sikking
2009-06-19 17:37:46 UTC (over 16 years ago)
lgm talk, part 2...
guys,
the second part of my lgm talk is blogged now:
enjoy,
--ps
yahvuu
2009-06-19 18:05:01 UTC (over 16 years ago)
lgm talk, part 2...
Hi all,
there's one thing i don't understand, may be a misconception: why is it necessary to have separate modes for editing the RGB data and the plates?
For example, if i have an RGB image in the composition and want to apply 'value curves', that has to be done in the RGB area, for after separation the plates are treated individually. Now only after manually pulling over the 'press projection' again i can discover that this operation
drove my plates out of gamut.
Is it correct that there's no 'live preview' of the effects that RGB manipulations have on the plates?
greetings, peter
peter sikking
2009-06-19 18:34:34 UTC (over 16 years ago)
lgm talk, part 2...
mainly because creating art on a RGB monitor, to be used on many media, is not the same _activity_ as bringing this art to _one_ particular printing press.
also, it is better when the art itself is separated from the adaptation of
it for one press run.
the question is what is the curve for? is it artistic? then RGB is your space. getting the plates right? then chain them together and do a curve.
Now only after manually pulling over the 'press projection' again i can discover that this operation drove my plates out of gamut.
there is going to be no substitute for experience with printing presses and especially the particular press one is working towards.
if that is really needed by some users (see the two activities above and also "no substitute for experience") then a second view of the file (View->New view) can be run with the projection pulled down. might be hard on the processor.
--ps
2009-06-19 18:56:27 UTC (over 16 years ago)
lgm talk, part 2...
In 21st century there are no RGB curves :) There are LAB and L*c*h* ones ;)
Alexandre
Chris Mohler
2009-06-19 19:01:07 UTC (over 16 years ago)
lgm talk, part 2...
On Fri, Jun 19, 2009 at 10:37 AM, peter sikking wrote:
guys,
I like this approach.
I have a few questions:
Will each plate have a density or opacity attribute? (some inks are more opaque than others)
Will it be possible to edit an individual plate in grayscale?
And finally, will it be possible to perform operations on the RGB portion of the image that do not take (immediate) effect on the projection? For example, if I want to go back and add a portion of my RGB artwork to a plate, I might want to clone and existing RGB layer, perform some modifications, then apply the contents of that new layer to one of the plates.
Thanks,
Chris
peter sikking
2009-06-19 19:41:41 UTC (over 16 years ago)
lgm talk, part 2...
I guess that the complexities of ink simulation start showing here.
well, as pippin said: the individual plates _are_ grayscale/monochrome drawables. they will be editable just like layer masks or selections.
I am curious why you want to do something like that, because you are then going against the grain of the whole plan: freedom to develop the artistic concept further without (much) rework on the plates.
--ps
Øyvind Kolås
2009-06-19 23:16:44 UTC (over 16 years ago)
lgm talk, part 2...
Not that the difference really matter as both linear light RGB and CIE Lab are fully mutually transformable into each other. For CIE Lab or Lch it would only make proper sense to control the L, other controls can be used for tuning white point etc in those color models though.
/Øyvind K.
Chris Mohler
2009-06-19 23:41:54 UTC (over 16 years ago)
lgm talk, part 2...
Yes - although transparency/opacity would be enough for me to use GIMP for professional separation work. I'm reasonably sure that PS uses a variant of the blending mode Multiply for spot channels, and this works fairly well.
Excellent.
Imagine I'm designing a black t-shirt with say five spot colors, including white. After completing the artistic design, I enable the 'projection screen'. This theoretically would result in my five "plates". However, the white plate will need special attention.
Here's my workflow for this in PS: I would use the (badly named) 'Apply Image' command to take the contents of each color plate and combine them into the white plate using the mode 'multiply'. I would also manually "choke" the white plate - this means making the white areas a point or two smaller than the colored areas, thereby preventing the white from poking out at the edges of the colored areas. This process can get a bit tricky, especially if the original artwork is very complex. Often, create temporary layers (or plates), perform selection/drawing functions, then combine the result back into a plate in one of two ways - either making a selection on the temp layer and going to the plate and filling or erasing, or using the 'Apply Image' command to take the RGB channel of the current layer and combine it with a plate using a mode such as Multiply, Screen, or Add.
Now, I am quite interested in learning new workflows - so I am not bound to the "how" of the method above, but I hope I have explained the "why" well enough. In addition to being able to interact with each plate as a grayscale drawable, it would be useful to create temporary areas for doing work - be they layers, channels, plates, whatever - on which to create paths, selections, etc to in turn use to modify the plates manually. Icing on the cake would be a mechanism to combine/subtract plates using the available blending modes. During the process, it is fairly critical to have an ink density/opacity setting for each plate, to simulate (roughly) how the final print is going to look. EG, set the white plate at approx 90%, the colors at approx 70% - and you can see which portions of the colors are falling on the white underlay, and which portions are falling on the black shirt.
I realize that this is just one corner case, but if you visualize each plate being printed separately, in order, you may be able to recognize some of the many 'gotchas' inherent in separating the artistic artwork into something suitable to send to the press. That's why (in my opinion) it is important to have as much control as possible over each plate.
Whew ;)
If I explained any of this poorly, I am sorry and will happily try to do better.
All in all, I am very pleased with the direction that this is taking and I would certainly like to use GIMP for even more of my production work. :)
Thanks,
Chris
Andrew A. Gill
2009-06-20 01:25:01 UTC (over 16 years ago)
lgm talk, part 2...
On Fri, 19 Jun 2009, peter sikking wrote:
guys,
enjoy,
I do appreciate your work on this, but I have to say that I still have some concerns.
I have to go somewhere, so I haven't read evreything yet, but I'd like to make this point. Converting from CMYK to RGB and vice versa are not lossless by a long shot. This is by necessity and the fact that GEGL is non-destructive has nothing to do with it, since large porions of image data will have to be tossed when converting.
The gamut for RGB is far larger in the bright colors, and CMYK can produce effects that cannot be produced in RGB.
See, for example:
I am very concerned that your overlay concept would simply degrade the image over successive conversions.
Martin Nordholts
2009-06-20 10:13:24 UTC (over 16 years ago)
lgm talk, part 2...
guys,
enjoy,
Isn't it a good idea to first read what you are commenting on?
It seems to me you completely misunderstood the whole thing. What makes you think there is any CMYK -> RGB conversion involved here?
/ Martin
yahvuu
2009-06-20 16:22:35 UTC (over 16 years ago)
lgm talk, part 2...
hi,
also, it is better when the art itself is separated from the adaptation of it for one press run.
ah, that helps. So it is deprecated to create single-ink 'light blue text' directly on the 'light blue' plate, as the text would then not be known to be part of the artwork.
Can you give an outline how the print color for that text will be specified? The RGB color isn't useful here and the text layer can't be accessed while the press projection is pulled over, IIUC. So each artwork layer will have a custom color separation setting resp. color mapping?
sure. Gamut warnings can only ease the first step, by guiding the color separation process.
Regarding the use-case of matching one color from a photo with a predetermined ink combination, i think this will be useful.
greetings, peter
Tobias Ellinghaus
2009-06-20 17:02:47 UTC (over 16 years ago)
lgm talk, part 2...
Am Samstag, 20. Juni 2009 schrieb yahvuu:
From Peter's blog post:
"However there will be full flexibility to map the content of any layer directly to any plate. For instance that light blue text in our example: it can be directly mapped from its text layer to the light blue plate, bypassing the composite."
I understand that you can use layers as plates.
yahvuu
2009-06-20 18:27:00 UTC (over 16 years ago)
lgm talk, part 2...
hi,
Whew ;)
Whew, too ;) Makes me wonder if it has to be that hard or if it points to some missing software improvements. Trying to understand the example, i hope you don't mind some uninformed questions (and also some out-of-sequence quoting).
Besides anticipating printing press idiosyncrasies ('choke'), it seems to me you're manually creating kind of a color separation. Quite naively: doesn't photoshop know you're printing on black?
this is to create the white underpinning, resp. the beginning thereof. 'Apply Image' is short-hand for 'blend anything with anything', but doesn't do any tricks that could not be achieved with layer stacks in combination with proper channel masking. On track?
I would
if the artwork was fully vectorized, say a pure inkscape job, would that make things easier?
i assume the temporary layers are mostly grayscale?
the temporary layers serve as 'mixing stage' because it takes several steps to create a desired mask, or is it more to keep selections/drawings for reuse?
thanks for your patience, peter
Daniel Hornung
2009-06-20 18:40:22 UTC (over 16 years ago)
lgm talk, part 2...
Hello Martin!
/ Martin
I think Andrew referred to this part from Peter's article:
what about CMYK files?
When a received CMYK file is to be used in new creative work, we already saw that ‘it needs to be imported and converted to RGB.’
Daniel
Daniel Hornung
2009-06-20 18:43:32 UTC (over 16 years ago)
lgm talk, part 2...
Sorry, I just saw that Guillermo cleared up that misunderstanding already. (Though it was not detected as part of the same thread by my mail client.)
Daniel
yahvuu
2009-06-20 18:46:46 UTC (over 16 years ago)
lgm talk, part 2...
hi,
yep, that's the desired effect here. For the single-ink text example, a bit more than filling the light blue plate to 100% is required, though, as the other plates have to be set to 0% for that area.
My question is how and where such a layer->plate mapping will be specified, for example when i want my text to be (0, 0, 50%, 50% ,0) on the five plates.
greetings, peter
Chris Mohler
2009-06-20 18:52:53 UTC (over 16 years ago)
lgm talk, part 2...
On Sat, Jun 20, 2009 at 11:27 AM, yahvuu wrote:
hi,
Whew ;)
Yes - I end up doing a lot of it manually, and no it does not know - having a 'target' or 'base' would be a step forward.
Yes.
I would
Of course, but when photographic-type artwork comes into play, it's usually easier/faster to do the whole thing in a raster editor.
Usually RGB layers, or grayscale channels.
A little of both. Sometimes I just need a very complex selection, but I need to do some work to create the selection. Other times I need to store a selection for later use (that's generally when I make an extra channel).
After re-reading the notes on the talk, if we have a Layer->Plate mapping, I think that will cover most situations. I would prefer a way to "mix" the plates, and to be able to add new layers that could later be applied to new or existing plates, but this could be worked around.
Chris
yahvuu
2009-06-20 19:07:34 UTC (over 16 years ago)
lgm talk, part 2...
hi,
sorry, imprecise question. I mean, if you use a temporary RGB layer, it's content will still usually be just grayscale, effectively used as a mask. Assumed correctly?
greetings, peter
Chris Mohler
2009-06-20 19:24:58 UTC (over 16 years ago)
lgm talk, part 2...
On Sat, Jun 20, 2009 at 12:07 PM, yahvuu wrote:
hi,
Not necessarily - consider another scenario: mixing two spot colors to create a third color. More accurately, consider an image (RGB) that is primarily three colors, and then attempting to print that image in two colors, getting as close to the original RGB artwork as possible (the number of spot colors is a major factor in printing cost).
In that scenario, I may end up duplicating the original RGB artwork several times before getting the selection that I want - then ultimately filling or erasing that selection on the spot channel(s). The process can be very non-intuitive at times, and sometimes you just have to dive in and do some trial and error - esp. if the original RGB image is something flat that was not originally intended to be printed in such a way or is "damaged" (eg, not on layers, suffers from JPEG compression, etc.).
Chris
Hal V. Engel
2009-06-20 21:42:14 UTC (over 16 years ago)
lgm talk, part 2...
On Saturday 20 June 2009 09:40:22 am Daniel Hornung wrote:
Hello Martin!
/ Martin
And I am not sure that this is the correct approach. Why would this be needed? Is this so that we can deal with GIMPs limited functionality to handle anything beyond RGB color spaces? If so then the focus should be on supporting other color spaces directly.
I also have not any anything in the thread related to how color management fits. After all how do you create the printer specific separations from an RGB (or other non-device specific) image into the correct device values without involving the color management engine?
Hal
peter sikking
2009-06-21 18:22:22 UTC (over 16 years ago)
lgm talk, part 2...
more gluing:
this looks analogue to me to black generation in cmyk, but now inverted because we are on a black background. interesting concept, the media color (makes note). since it is going to work for black, it can be made to wok for any other color, with reversed logic also.
I would
this looks like trapping to me. is there a difference? trapping set-up for each plate would be in the projection set-up.
everything of that will work on plates like working on layers today. I am sure that global concepts like paths and selection will be applicable to layers and plates without limits. a selection created on a layer and applied to a plate: sure.
to generate plates from channels/layers that is needed, but generating plates from plates? sounds like a creative kind of workflow to me.
During
hmmm, tricky that one. it is natural for the plate stack to work sort-of like the layer stack. eye symbols to switch plates on/off. then there is the opacity slider of the layer stack. coverage slider for the plates? ay be does the dual purpose of previewing like you need and absolute print balancing.
"mixing" channels + layers -> plates is a starting point for the development of the design of the plate set-up.
add layers where, image side or press projection side?
--ps
peter sikking
2009-06-21 18:46:38 UTC (over 16 years ago)
lgm talk, part 2...
last one:
yes, but then I would not stop anybody from doing that. sometimes it will
be necessary like applying a ghost image in matte varnish on top of a glossy full color image: it may be most efficient to do the matte varnish plate from scratch by itself...
specify a color (pantone, RAL, etc.) for the plate.
no the other way around, each plate gets "mixed" from channels + layers. I know this is not simple nor solved at the moment. since the plate is a momochrome drawable, we need to look at the text layer and determine
per pixel "how much is there", where 'how much' can be a choice or combination of the (inverse of) value/lightness/alpha/layer opacity, and perhaps more.
reading this again I am getting confused what you really mean here.
yeah, I realised that. must be part of the set-up to do that.
well, plates 3 and 4 need to be set up (in the projection set-up) to take
0.5 * "the (inverse of) value/lightness/alpha/layer opacity"
--ps
Chris Mohler
2009-06-21 21:20:30 UTC (over 16 years ago)
lgm talk, part 2...
Yes, I think media color should be taken into account when designing this system - even though I suspect the vast majority of media will be white or very light.
 I would
A "choke" is a trap of negative amount. This is probably just jargon - I suspect that it should in fact be called a negative trap. Automatic trapping (and overprinting) has never lived up to my expectations - I would love to hear from anyone who has used auto-trapping software with acceptable results though.
OK - thanks for clarifying.
I remember one specific instance: printing two blue colors - one light, one medium - on very dark blue. We originally placed the light blue color behind the medium blue color (overprint). The client changed their mind, and I needed to remove the overprint. Merging the (inverted) contents of med blue into the contents of lt blue removed the overprint in one step. I basically masked one plate with another and applied the mask.
While I doubt that function is necessary, it would certainly be very useful on occasion.
 During
Indeed - the stack of plates should function more or less like the layer stack. Yes - I envision a visibility toggle for each layer, and also an opacity slider. But here's another murky area (as if we needed more ;) - if I set a plate's opacity to 50%, does 100% black on that plate print out at 50% or 100%? I would expect 100% - but that's from past experience, and not very intuitive. Perhaps you are right that we need both a opacity and coverage control - that makes more sense to me, but I have never seen it implemented and may well prove confusing.
OK - thanks.
My guess is image-side. One possible scenario:
1. Design artwork in GIMP - RGB, 3 colors, 1 color per layer - 3 layers (or maybe 4 with a bg color)
2. Create print projection, map layers to plates 3. Done, hit print/export - OR
4. Go back to RGB, duplicate two layers, merge them, apply curves, etc - whatever needs adjustment
5. Manually apply the contents of the new layer to one or more of the plates in the projection
6. Done, print/export
I guess to summarize: in addition to the initial layer(or color?) -> plate mapping, it should be possible to re-apply contents of one or more RGB layer to the plates without re-mapping the entire projection (if that makes sense).
Things like overprints and trapping can get very complicated, esp if the colors are not solid and/or you are mixing spot colors. Often fine-tuning is required. I would love to see automatic trapping (complicated!), but not without being able to manually tune the results
I'd like to thank everyone for participating in this discussion! I like the direction that this is headed... Chris
Graeme Gill
2009-06-22 14:32:15 UTC (over 16 years ago)
lgm talk, part 2...
Chris Mohler wrote:
I would
Note that "trapping" has two meanings in the printing world.
One relates to the way the inks stick to what it's being printed over :- ie. if one plate printed on paper achieves 100% trap (coverage), then when it's printed on top of a previous plate it might have 90% trap because it doesn't stick as well to ink as paper, etc.
The other relates to "choke and spread", used to create plate alignment (registration) tolerance.
Graeme Gill.
peter sikking
2009-06-22 16:21:15 UTC (over 16 years ago)
lgm talk, part 2...
Chris Mohler wrote:
I would
would you call setting for each plate the amount (in points or micrometers,
etc) of choking or trapping to be automatic or manual?
and now it looks like a plate set-up change
During
no it would have to be a slider with results, so it would really scale the whole plate coverage. and similar to layer opacity today you can use it in between to peek though a layer. that should be enough
OK, all clear there.
well, if you want some layers to do something special to some plates you will have to map them. this does not mean re-doing your mapping, just updating it a bit.
for instance using the (perpetual) upcoming iWarp tool on the plate would a cool way to do thet, no?
--ps
