retrieve info from gimp via script-fu-server
retrieve info from gimp via script-fu-server Ioan Calin Borcoman 18 May 15:40
  retrieve info from gimp via script-fu-server Sven Neumann 19 May 07:36
Ioan Calin Borcoman
2009-05-18 15:40:53 UTC (almost 16 years ago)
1. Is it possible to obtain any info from the script-fu-server except 'Success'? For example, if I send '(gimp-image-get-name 1)' for execution to the server, I would expect to receive something like 'foo.xcf' (or 'Untitled', if a new file is opened, for example). Instead of that, I receive only 'Success'. Any ideas on what is missing?
2. Is it possible to have script-fu-server started automatically when gimp starts? How?
Thanx,
Ionutz
2009-05-19 07:36:57 UTC (almost 16 years ago)
As I already said, script-fu-server is nothing but a code example to show you how a plug-in can export the PDB functionality. If you actually need such an interface, I suggest that you start from scratch after having understood how script-fu-server works.
If I would be in the need to control GIMP from outside, I'd write an extension that exports the PDB over D-Bus. That should be relatively easy and it would be useful enough that we should consider to include it instead of the script-fu-server code, which is pretty much useless except as an example.
