Apply transforms on double click
Apply transforms on double click Chandana Bandara 11 Apr 00:27
  Apply transforms on double click Martin Nordholts 11 Apr 00:56
   Apply transforms on double click Chandana Bandara 11 Apr 01:13
    Apply transforms on double click Martin Nordholts 11 Apr 07:20
Chandana Bandara
2009-04-11 00:27:09 UTC (about 16 years ago)
I would like to raise an enhancement for gimp.
*Apply transforms on double click*
The current situation is, after a picture transformation, i.e. change the parameters by hand in the pop-up dialog box, or using mouse pointer to make the transformation on the picture itself, the user can either press ENTER button or click on the respective button on the pop-up dialog box to apply it.
It is good if the user can DOUBLE-CLICK on the picture after the transformation has done. This gives the user easiness when the user do the transformation by the mouse pointer. Otherwise he/she has to use hand on keyboard or move the mouse pointer to somewhere else to apply the transformation.
Since I was applied for the GSoC this time, I would like to make a patch for this to familiarize myself with GIMP if it is recommended by the community.
Thanking you.
** Chandana Bandara IRC: boneyCB
Martin Nordholts
2009-04-11 00:56:33 UTC (about 16 years ago)
_Apply transforms on double click_
Hi
Just so you know, the transformation tools are eventually going to be merged and work differently (the popups will be removed)
- Martin
Chandana Bandara
2009-04-11 01:13:43 UTC (about 16 years ago)
Thank you for the information. It is nice to hear that those tools are going to be merged and hence will be improved. It will be easier for the user to select one tool and make transformations there. I have seen that in some softwares.
Is that merging those tools related to the the GSoC project Implement perspective transformations in GEGL?
Chandana Bandara
Hi
- Martin
Martin Nordholts
2009-04-11 07:20:08 UTC (about 16 years ago)
Not really, they are mostly separate issues
- Martin
