gegl/gegl documentation patch
gegl/gegl documentation patch Henrik Akesson 16 Mar 12:55
  gegl/gegl documentation patch Martin Nordholts 18 Mar 20:41
   gegl/gegl documentation patch Øyvind Kolås 19 Mar 11:40
Henrik Akesson
2009-03-16 12:55:01 UTC (about 16 years ago)
Here's a patch for:
- Documentation and debug statements added - Removed needs_visiting from the gegl-visitable interface and the implementing classes gegl-pad and gegl-node because it was not used (hardcoded to return TRUE).
- Refactored gegl-eval-mgr field "state" to use an enumeration instead of integers for improving readability of the code.
/Henrik
Martin Nordholts
2009-03-18 20:41:24 UTC (about 16 years ago)
Henrik Akesson wrote:
Here's a patch for:
Thanks! I have split up the patch in three separate commits and commited. I left out the g_debug() debug code for now since it is enabled by default which is too intrusive IMO, I think such output should require setting a flag before it's enabled.
- Martin
2009-03-18 Martin Nordholts
Apply patch from Henrik Akesson that turns GeglEvalMgr::state into an enum instead of using pure ints since that increases readability.
* gegl/process/gegl-eval-mgr.[ch]
Apply patch from Henrik Akesson that adds documentation to the graph parts of the GEGL core in form of comments.
* gegl/graph/gegl-node.c * gegl/graph/gegl-visitor.c
* gegl/operation/gegl-operation.c * gegl/process/gegl-cr-visitor.c * gegl/process/gegl-eval-mgr.[ch] * gegl/process/gegl-have-visitor.c * gegl/process/gegl-prepare-visitor.c
Apply patch from Henrik Akesson that removes the superfluous GeglVisitableClass::needs_visiting() and all code that depends on it such as the GeglNode and GeglPad implementations (both of which just returned TRUE) and the calls to the method.
* gegl/graph/gegl-node.c * gegl/graph/gegl-pad.c
* gegl/graph/gegl-visitable.[ch] * gegl/graph/gegl-visitor.c
Øyvind Kolås
2009-03-19 11:40:19 UTC (about 16 years ago)
Here's a patch for:
- Martin
GEGL has built in mechanisms for logging debug information.
GEGL_NOTE (CACHE, "foo %s", bar); GEGL_TIMESTAMP(PROCESSOR);
GEGL_MARK()
Where CACHE and PROCESSOR is used the following logging domains are available:
PROCESS, CACHE, BUFFER_LOAD, BUFFER_SAVE, TILE_BACKEND and PROCESSOR
Actual printing of these can be enabled by setting the GEGL_DEBUG environment variable like:
GEGL_DEBUG=processor,cache
or even
GEGL_DEBUG=all
/Øyvind K.
