Testing
Testing Henrik Akesson 13 Mar 15:38
  Testing Øyvind Kolås 13 Mar 16:12
   Testing Martin Nordholts 13 Mar 17:38
    Testing Martin Nordholts 21 Mar 12:30
Henrik Akesson
2009-03-13 15:38:20 UTC (about 16 years ago)
Testing
I'd like to set up some regression tests before doing any changes to the code.
You agree on using the glib test framework?
I'll do it by applying some operations on an input image file and comparing the resulting output image file with a reference. However, I suppose that this is not platform independent. There would be slight differences in the precision of the calculations, resulting in slightly different pixel values and files that are not at all comparable.
Any ideas/suggestions?
Henrik
Øyvind Kolås
2009-03-13 16:12:43 UTC (about 16 years ago)
Testing
The gallery in docs/ could be extended to also store reference images. I've been using this setup to look for rendering and performance regressions (it used to even be built and have a browsable multi-architecture continous build and testing at Open Source Development Labs but that effort was shut down with some of OSDLs cut-backs in Engineering operations).
There is a set of regression tests for GeglBuffer in tests/buffer which outputs grayscale images as unicode and uses unified diffs to detects differences, I think Martin Nordholts has mentioned that he wants to port these tests to use glib test framework.
/Øyvind K.
Martin Nordholts
2009-03-13 17:38:49 UTC (about 16 years ago)
Testing
I am also in the process of writing regression tests and refactoring code. I use the simple TESTS feature in automake, check out the tests sub directory that has one test already.
Regarding porting the GeglBuffer tests to something I'm not sure I will do that in the near future. As long as they can be run I'm satisfied.
- Martin
Martin Nordholts
2009-03-21 12:30:39 UTC (about 16 years ago)
Testing
- Martin
I just ported the buffer tests to automake
- Martin
2009-03-21 Martin Nordholts
Port buffer tests to automake which has a couple of benefits. First of all they are run and results reported during a normal make check, and second of all the tests are run against the build and not against a possibly non-existant installation based on hardcoded prefixes.
* configure.ac * tests/Makefile.am
* tests/buffer/Makefile.am
* tests/buffer/buffer-tests-results.sh
